By itay231
#35485 yes, i specified it in my sketch.
i don't think i need DMZ because it works fine in my LAN, so when i write 192.168.1.150:802 (150 for example) it works.
Anyway i find out my ISP using NAT and i think that's why it's not working on the WAN.
Does anyone know a way to make it work with NAT? without changing ISP?
By reaper7
#35493 or, if You know Your external IP, check with this site: http://www.canyouseeme.org/ whether selected port is visible "from outside".
This is better option, because probably when You can try check it from eg. computer connected to the same local network with esp8266, such a loop is generally not possible to realize through Your router.
P.S. You can try test access to esp with mobile phone too, but when mobile is connected via LTE/GPRS etc (not via Your router)
