By Axelotl
#41372 Hi everybody,
before I did this mistake my ESP8266 ESP01 modul worked fine. But the firmware was old so I decided to update that thing. I did this with the "ESP FLASH DOWNLOAD TOOL V2.3" at the baudrate of 9600 (default for old firmware). The latest firmware (ESP8266_NONOS_SDK_V1.5.1_16_01_08 ) I downloaded from the Espressif homepage. This bin files were flashed to the respective adresses:
esp_init_data_default.bin -> 0xFC000
blank.bin -> 0xFE000
boot_v1.5.bin -> 0x00000
user1.1024.new.2.bin -> 0x01000
after that the modul work also fine, but at a baudrate of 115200. This is to fast for the SoftwareSerial of an arduino. So I changed the baudrate with the command:
AT+IPR=19200
Now nothing works. I cannot communicate to the modul, neither with 19200 nor any other baudrate, the one I get are some strange symbols and then the blue LED stays on. It doesn't react on any commands. New flash is not possible because the Flash tool doesn't have a 19200 baudrate. With other flash tools the connection failes at 19200 and other baudrates.
What can I do to rescue my little modul? Is there a chance to change the baudrate back to 115200 or 9600? or do I miss something.
thanx for help!
By Axelotl
#41450 Thanx for the reply!
I now find out that the baudrate is 9600 in the flash mode of this modul, so I was able to reflash. After reflashing the baudrate is set back to 115200.
But this is to fast for SoftwareSerial of an arduino. I want to use this modul with an arduino so I have to set it lower than 115200.
I tryed it with:
AT+IPR=19200 and AT+UART_DEF=19200,8,1,0,3
But both of them do not work. After setting the baudrate there is no communication possible. Neither at 115200 nor 19200.
Do you mean that I can change the baudrate in the tool "ESP FLASH DOWNLOAD TOOL V2.3" before flashing? I cannot find such a setting. Or is there another AT-command to change the baudrate?
