Help with arduinoWebSockets
Posted: Sat Feb 20, 2016 1:29 pm
Hello,
I have an ArduCAM mini connected to my ESP8266 (NodeMCU Amica) running in the Arduino environment. I'm try to use a websocket connection to Firefox for displaying the images acquired by the camera. I'm using the arduinoWebSockets library from https://github.com/Links2004/arduinoWebSockets.
I have an HTML page with connect/disconnect buttons and an capture image button. With this code I can connect to the websockets server and pass a "capture" message. The websockets server code always sees this message and it then acquires an image and attempts to pass it back to the browser as an arraybuffer. I'm using the following to send the jpeg encoded image back to the server:
I've already dumped the imageBuffer and it looks like a valid JPEG image.
The onmessage function in the HTML should receive the data but never does. I know this because the alert is not triggered.
When I turn on the debug feature in the arduinoWebSockets code I see the image data was sent. Here is the output from the serial monitor.
If I click the capture button three times, I get a websocket error from Firefox and an additional message saying the
Image corrupt or truncated. URI in this note truncated due to length.
Does anyone have an idea of what I am doing wrong?
BTW I am using the stable version of the esp8266 Arduino code.
TIA
webSocket.sendBIN(0, imageBuffer, i);
function StartCamera() {
var url = $('#wsURL').val();
sl_ws = new WebSocket(url);
sl_ws.binaryType = 'arraybuffer';
sl_ws.onopen = function() {
alert("WebSocket Connected");
sl_ws.onerror = function() {
alert("WebSocket Error");
sl_ws.onmessage = function(event) {
alert("WebSocket Data Received");
var wsRecvMsg = event.data;
var cameraStream = new Uint8Array(wsRecvMsg);
var camerascreen = document.getElementById('camerascreen');
camerascreen.src = 'data:image/jpeg;base64,'+encode(cameraStream);
captureImage called
Image captured
sendImage called
Image size: 8192
[WS][0][sendFrame] ------- send massage frame -------
[WS][0][sendFrame] fin: 1 opCode: 2 mask: 0 length: 8019 headerToPayload: 0
[WS][0][sendFrame] sending Frame Done (11017us).
Image data sent: 8019
TIA
