By alonewolfx2
#24285
John A wrote:I'am using the code of Abel but i do not get any character on the display. Only the cursor on the end of the text. Any idea what can be?
Thank you in advance.
Can you provide code link?
By John A
#24287 Thank you for your help! I a new user of the ESP8266.
The code i use was from Abel on an previous post:
Code: Select all-- PCF8574
-- P7 P6 P5 P4 P3 P2 P1 P0
-- D7 D6 D5 D4 (BL) EN RW RS
-- HD44780
id = 0
sda = 4 -- GPIO2
scl = 5 -- GPIO14
dev = 0x27 -- PCF8574
reg = 0x4e -- write
i2c.setup(id, sda, scl, i2c.SLOW)
function send(data)
local bl = 0x00 -- 0x08 = back light on
local value = {}
for i = 1, #data do
table.insert(value, data[i] + bl + 0x04 + rs)
table.insert(value, data[i] + bl + rs) -- fall edge to write
i2c.start(id)
i2c.address(id, dev ,i2c.TRANSMITTER)
i2c.write(id, reg, value)
i2c.stop(id)
-- init
rs = 0
send({0x30})
tmr.delay(4100)
send({0x30})
tmr.delay(100)
send({0x30})
send({0x20, 0x20, 0x80}) -- 4 bit, 2 line
send({0x00, 0x10}) -- display clear
send({0x00, 0xf0}) -- display on
nibble = {
["0"] = 0x00,
["1"] = 0x10,
["2"] = 0x20,
["3"] = 0x30,
["4"] = 0x40,
["5"] = 0x50,
["6"] = 0x60,
["7"] = 0x70,
["8"] = 0x80,
["9"] = 0x90,
["a"] = 0xa0,
["b"] = 0xb0,
["c"] = 0xc0,
["d"] = 0xd0,
["e"] = 0xe0,
["f"] = 0xf0
rs = 1
str = "Hello World!"
for i = 1, #str do
local char = string.byte(string.sub(str, i, i))
send({
nibble[string.sub(string.format("%x", char), 1, -2)],
nibble[string.sub(string.format("%x", char), 2)]
The strange why is blinking the "cursor" in the end of the text and do not appear the text.
By alonewolfx2
#24293 can you try to change str = "Hello World!" to str = "12345" and try again ?
