By nodduino
#4019
frasenci wrote:Do not discard the "faulty" one ESP.
Just try again powering from an robust 3.3 V source.
Greetings
Francisco
Thank you for the suggestion. I'll give it a try when I receive the voltage regulator.
By boff
#4746 Hi,
I had a module which showed all the symptoms that you describe, ie continuous blue light and garbage from the Tx pin.
In desperation I tried to re-flash it and this was successful. I have had no problems since then. :P
The new firmware also allows me to change the baud rate which is very useful.
http://blog.electrodragon.com/cloud-upd ... p8266-now/
By Kapil Rathi
#10487 I used esp8266 with cp2102 with RC/TX and TX/RX, VCC & CH_PD -> 3.3v (from LD33v), GND-0v. As soon as I open Serial monitor, it shows never ending garbage data untill I close that. I change the baud rate also but no change. What should I do in that case?
Thanks
Kapil
