By Latschen
#49989 Hello Guys!
I don't get a problem with my ESP8266 module solved. I simply want to use the module as a client in an existing WLAN. I can communicate with it and send AT-* commands, for example I can list all access points, set CWMODE, and also join my network via AT+CWJAP.
But the module does not get a valid IP address via DHCP from my router, so I can not ping my module. It always assigns me this IP:
IP: AT+CIFSR
+CIFSR:STAIP,"48.56.52.5"
+CIFSR:STAMAC,"32:2d:13:45:dd:04"
But my network IPs are 192.168.0.*.
Here is my setup:
I use a (sunfounder) arduino ONE and connected RX and TX to the according ports. I use 3,3V from arduino (yes I know that this might be too weak) and 5V on the digital pins (yes I know that I should use 3,3v here, too).
I successfully flashed the ESP8266 with "v1.3.0.2 AT Firmware"
So do you have any hints for me what I am doing wrong I would realy appreciate every possible hint because I am searching for four days now for a solution :(
Thank you and kind regards,
Tobias
By Latschen
#50004 Hey Guys!
It's always the same. Hours and Hours of searching, and then, finally, 15 minutes after writing a long post entry, finding the solution.
For all having the same problem as me:
It is:
AT+CWDHCP=1,1
first "1" for server mode (0,1,2 = client, server, both), second "1" for enable/disable (0/1).
Tobias
google that and you will find good explanation abou
