By katz
#55566 Hello all,
I've been trying to get websockets to run on the ESP8266 and I finally got it working. I assume that you can read the program and figure out what is going on. The code below should work 'out of the box' just check it out, upload it to your ESP and start your browser. It displays the runtime, a datacounter, a slider and a button. You can regulate an LED with the slider and the button. My LED is on pin 16, yours may be on another pin, you can set it on line 8. Don't forget to set your WIFI loginname and password in lines 6 and 7.
Try opening the ESP-website in two browsers. Notice how changes you apply in one browser are updated in the second browser also ... it's magic. Websockets are a new technology that may not work in older browsers. On line 33 the website controls the slider with an ONCHANGE command. This works fine if you use Internet Explorer but in Firefox an Chrome you should replace ONCHANGE with ONINPUT.
Enjoy! Peter.
#include <WebSocketsServer.h>
#include <ESP8266WebServer.h>
// DEFAULT variables *********************************************************
const char* ssid="yourSSID";             // yourSSID
const char* password="yourPASSWORD";     // yourPASSWORD
int LED=16;                              // PINnumber where your LED is
int websockMillis=50;                    // SocketVariables are sent to client every 50 milliseconds
int sliderVal=60;                        // Default value of the slider
// END ***********************************************************************
ESP8266WebServer server(80);
WebSocketsServer webSocket=WebSocketsServer(88);
String webSite,javaScript,JSONtxt;
unsigned long websockCount=0UL,wait000=0UL,wait001=0UL;
int LEDmillis=9*(100-sliderVal)+100;
boolean LEDonoff=true;
void buildWebsite(){
  buildJavascript();
  webSite="<!DOCTYPE HTML><HTML>\n";
  webSite+="<META name='viewport' content='width=device-width, initial-scale=1'>\n";
  webSite+=javaScript;
  webSite+="<BODY>\n";
  webSite+="<BR><B>This is the ESP website ...</B><BR><BR>\n";
  webSite+="Runtime = <A ID='runtime'></A><BR>\n";
  webSite+="websockCount = <A ID='websockCount'></A><BR><BR>\n";
  webSite+="<TABLE BORDER=1 WIDTH=200px BGCOLOR='cornsilk' STYLE='border-collapse:collapse;text-align:center'>\n";
  webSite+="<TR><TD>Slidervalue = <A ID='Sliderval'></A><BR>\n";
  webSite+="LEDspeed = <A ID='LEDmillis'></A> ms</TD></TR>\n";
  //********** ONCHANGE works in IE, use ONINPUT in Firefox and Chrome **********
  webSite+="<TR><TD><INPUT ID='slider' TYPE='range' ONCHANGE='Slider()' STYLE='writing-mode:bt-lr;-webkit-appearance:slider-vertical;' orient='vertical'></TD></TR>\n";
  webSite+="<TR><TD><BUTTON ID='button' ONCLICK='button()' STYLE='width:110px;height:40px'></BUTTON></TD></TR>\n";
  webSite+="</TABLE>\n";
  webSite+="</BODY>\n";
  webSite+="</HTML>\n";
void buildJavascript(){
  javaScript="<SCRIPT>\n";
  javaScript+="InitWebSocket();\n";
  javaScript+="function InitWebSocket(){\n";
  javaScript+="  websock=new WebSocket('ws://'+window.location.hostname+':88/');\n";
  javaScript+="  websock.onmessage=function(evt){\n";
  javaScript+="    JSONobj=JSON.parse(evt.data);\n";
  javaScript+="    document.getElementById('runtime').innerHTML=JSONobj.runtime;\n";
  javaScript+="    document.getElementById('websockCount').innerHTML=JSONobj.websockCount;\n";
  javaScript+="    document.getElementById('slider').value=JSONobj.sliderVal;\n";
  javaScript+="    document.getElementById('Sliderval').innerHTML=JSONobj.sliderVal;\n";
  javaScript+="    document.getElementById('LEDmillis').innerHTML=JSONobj.LEDmillis;\n";
  javaScript+="    document.getElementById('button').innerHTML=JSONobj.LEDonoff;\n";
  javaScript+="  }\n";
  javaScript+="}\n";
  javaScript+="function button(){\n";
  javaScript+="  btn='LEDonoff=LED = ON';\n";
  javaScript+="  if(document.getElementById('button').innerHTML==='LED = ON')btn='LEDonoff=LED = OFF';\n";
  javaScript+="  websock.send(btn);\n";
  javaScript+="}\n";
  javaScript+="function Slider(){\n";
  javaScript+="  sliderVal=document.getElementById('slider').value;\n";
  javaScript+="  websock.send('sliderVal='+sliderVal);\n";
  javaScript+="}\n";
  javaScript+="</SCRIPT>\n";
String millis2time(){
  String Time="";
  unsigned long ss;
  byte mm,hh;
  ss=millis()/1000;
  hh=ss/3600;
  mm=(ss-hh*3600)/60;
  ss=(ss-hh*3600)-mm*60;
  if(hh<10)Time+="0";
  Time+=(String)hh+":";
  if(mm<10)Time+="0";
  Time+=(String)mm+":";
  if(ss<10)Time+="0";
  Time+=(String)ss;
  return Time;
void handleWebsite(){
  buildWebsite();
  server.send(200,"text/html",webSite);
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t wslength){
  String payloadString=(const char *)payload;
  //Serial.println("payload: '"+payloadString+"', channel: "+(String)num);
  if(type==WStype_TEXT){
    byte separator=payloadString.indexOf('=');
    String var=payloadString.substring(0,separator);
    String val=payloadString.substring(separator+1);
    if(var=="LEDonoff"){
      LEDonoff=false;
      if(val=="LED = ON")LEDonoff=true;
      digitalWrite(LED,HIGH);
    }else if(var=="sliderVal"){
      sliderVal=val.toInt();
  pinMode(LED,OUTPUT);
  WiFi.begin(ssid,password);
  while(WiFi.status()!=WL_CONNECTED)delay(500);
  WiFi.mode(WIFI_STA);
  Serial.println("\n\nBOOTING ESP8266 ...");
  Serial.println(ssid);
  Serial.print("Station IP address = ");
  server.on("/",handleWebsite);
  server.begin();
  webSocket.begin();
  webSocket.onEvent(webSocketEvent);
  webSocket.loop();
  server.handleClient();
  if(millis()>wait000&&LEDonoff==true){
    digitalWrite(LED,!digitalRead(LED));
    wait000=millis()+LEDmillis;
  if(millis()>wait001){
    websockCount++;
    String LEDswitch="LED = OFF";
    if(LEDonoff==true)LEDswitch="LED = ON";
    JSONtxt="{\"runtime\":\""+millis2time()+"\","+              // JSON requires double quotes
             "\"websockCount\":\""+(String)websockCount+"\","+
             "\"sliderVal\":\""+(String)sliderVal+"\","+
             "\"LEDmillis\":\""+(String)LEDmillis+"\","+
             "\"LEDonoff\":\""+LEDswitch+"\"}";
    webSocket.broadcastTXT(JSONtxt);
    wait001=millis()+websockMillis;
By rudy
#55598 With two clients sync gets messed up sometimes when you drag the slider. I have noticed this kind of thing with another similar slider sketch.
Otherwise it is quite nice. I think I will play with it a while and see what I can do with it.
By Me-no-dev
#55605 If you go async, you will not have those problems :) Using synchronous networking lets you handle only one thing at the same time (WS Client1, WS Client 2, Web Requests) and in async those work seamlessly together.
By rudy
#55682
Me-no-dev wrote:If you go async, you will not have those problems :)
Only if I could understand how it works. You have a wonderful example but it is overwhelming. Simpler examples would be more helpful. Learn to walk before run.
Examples that would be useful:
    Serve a web page with static content. Hello world.
    A simple button and led example, display A0
    The sketch above converted to async.
