Re: Change IP and port in AP mode
Posted: Thu Jan 12, 2017 9:31 am
martinayotte wrote:Fiest, you are talking about AT command, but you are using an Arduino sketch.
Beware that when you upload Arduino sketch, the AT firmware is gone/erased.
For you code, I don't see any client.available(), so it doesn't check if characters are received.
Check the following code instead :Code: Select allvoid loop()
if (client) {
if (client.available()) { // <--- here is the missing part
Serial.println(req);
client.flush();
Serial1.println("Client disonnected");
Yes! I know. I use terminal and AT commands to check my mobile app. this app have several buttons and when press each buttons on mobile app, send a string on port "8888" that received on terminal
now erase firmware and wish write a skatch to read this string and turn on/off gpio
I use Arduino 1.8.0 downloaded from arduino.org and "http://arduino.esp8266.com/stable/package_esp8266com_index.json"
I compile your code but following error reports
exit status 1
'class ESP8266WebServer' has no member named 'available'
