By Manudax
#30064 Hi,
very appreciated code but
not so advanced in javascript as your level,
I dont know how to had another value to the buildXML and how to display it.
A little help would be very useful.
#include <ESP8266WebServer.h>
ESP8266WebServer server(80);
const char* ssid="SSID";
const char* password="password";
String webSite,javaScript,XML;
int sensorPin = A0;   // select the input pin for ldr
int sensorValue = 0;  // variable to store the value coming from the sensor
void buildWebsite(){
  buildJavascript();
  webSite="<!DOCTYPE HTML>\n";
  webSite+=javaScript;
  webSite+="<BODY onload='process()'>\n";
  webSite+="<BR>This is the ESP website ...<BR>\n";
  webSite+="Runtime = <A id='runtime'></A><BR>\n";
  webSite+="LDR = <A id='LDR'></A>\n";
  webSite+="</BODY>\n";
  webSite+="</HTML>\n";
void buildJavascript(){
  javaScript="<SCRIPT>\n";
  javaScript+="var xmlHttp=createXmlHttpObject();\n";
  javaScript+="function createXmlHttpObject(){\n";
  javaScript+=" if(window.XMLHttpRequest){\n";
  javaScript+="    xmlHttp=new XMLHttpRequest();\n";
  javaScript+=" }else{\n";
  javaScript+="    xmlHttp=new ActiveXObject('Microsoft.XMLHTTP');\n";
  javaScript+=" }\n";
  javaScript+=" return xmlHttp;\n";
  javaScript+="}\n";
  javaScript+="function process(){\n";
  javaScript+=" if(xmlHttp.readyState==0 || xmlHttp.readyState==4){\n";
  javaScript+="   xmlHttp.open('PUT','xml',true);\n";
  javaScript+="   xmlHttp.onreadystatechange=handleServerResponse;\n"; // no brackets?????
  javaScript+="   xmlHttp.send(null);\n";
  javaScript+=" }\n";
  javaScript+=" setTimeout('process()',1000);\n";
  javaScript+="}\n";
  javaScript+="function handleServerResponse(){\n";
  javaScript+=" if(xmlHttp.readyState==4 && xmlHttp.status==200){\n";
  javaScript+="   xmlResponse=xmlHttp.responseXML;\n";
  javaScript+="   xmldoc = xmlResponse.getElementsByTagName('response');\n";
  javaScript+="   message = xmldoc[0].firstChild.nodeValue;\n";
  javaScript+="   document.getElementById('runtime').innerHTML=message;\n";
  javaScript+="   xmldoc = xmlResponse.getElementsByTagName('responseLDR');\n";
  javaScript+="   document.getElementById('LDR').innerHTML=message;\n";
  javaScript+=" }\n";
  javaScript+="}\n";
  javaScript+="</SCRIPT>\n";
void buildXML(){
  XML="<?xml version='1.0'?>";
  XML+="<response>";
  XML+=millis2time();
  XML+="</response>";
  XML+="<responseLDR>";
  XML+=sensorValue;
  XML+="</responseLDR>";
String millis2time(){
  String Time="";
  unsigned long ss;
  byte mm,hh;
  ss=millis()/1000;
  hh=ss/3600;
  mm=(ss-hh*3600)/60;
  ss=(ss-hh*3600)-mm*60;
  if(hh<10)Time+="0";
  Time+=(String)hh+":";
  if(mm<10)Time+="0";
  Time+=(String)mm+":";
  if(ss<10)Time+="0";
  Time+=(String)ss;
  return Time;
void handleWebsite(){
  buildWebsite();
  server.send(200,"text/html",webSite);
void handleXML(){
  buildXML();
  server.send(200,"text/xml",XML);
  WiFi.begin(ssid,password);
  while(WiFi.status()!=WL_CONNECTED)delay(500);
  WiFi.mode(WIFI_STA);
  Serial.println("\n\nBOOTING ESP8266 ...");
  Serial.println(ssid);
  Serial.print("Station IP address: ");
  server.on("/",handleWebsite);
  server.on("/xml",handleXML);
  server.begin();
  sensorValue = analogRead(sensorPin);
  delay(250);
  server.handleClient();
By Manudax
#30065 I finaly found the solution when I checked the xml structure.
  buildJavascript();
  javaScript+=" }\n";
  javaScript+="}\n";
  javaScript+=" }\n";
  javaScript+="}\n";
  javaScript+=" }\n";
  javaScript+="}\n";
void buildXML(){
  XML+="<Donnees>";
    XML+="<response>";
    XML+=millis2time();
    XML+="</response>";
   XML+=sensorValue;
  XML+="</Donnees>";
  String Time="";
  unsigned long ss;
  byte mm,hh;
  ss=millis()/1000;
  hh=ss/3600;
  mm=(ss-hh*3600)/60;
  if(hh<10)Time+="0";
  if(mm<10)Time+="0";
  if(ss<10)Time+="0";
  Time+=(String)ss;
  return Time;
  buildWebsite();
void handleXML(){
  buildXML();
  server.begin();
  delay(250);
Thank's again for your code.
By jgolden
#38266 Thank you so much for the code example! This has made monitoring the gpio very easy. Is there any way to toggle an output from the web page? I am still learning the java and html so any clues would be great!
By martinayotte
#38309 Simply add new handlers for that new URL, and add buttons to webpage which have onClick calling some Ajax with those URL :
Code: Select allserver.on("/gpio-high", handleGPIO_HIGH);
server.on("/gpio-low", handleGPIO_LOW);
