By gerardwr
#49276
gianni wrote:... using this method I adopted the java code becomes very large.
If the slider become 10, as I tried, and html code is big too, I've problem to load webpage on the browser (white page is displayed on the browser).
Hi,
I had a similar problem with sending a large webpage in a string to the client. The webpage was only partly received by the client, and did not show in the browser.
The client.print or client.send seems to send up to something like 2900? characters, the rest is cut off. If you need to send more than 2900? characters you will have to send it in chunks. I use this in my sketch:
Code: Select all    // Send the response to the client, because of the length sending multiple chunks is required
    // beware maximum length for println = 2900? on ESP
    for (int chunk=0;chunk <= (String(html_page).length()/2000);chunk++){
      client.print(String(html_page).substring(0+chunk*2000,2000+chunk*2000));
      delay(1);
Note : I'm not sure what the exact maximum is, but I read it's something around 2900. Maximising chunks at 2000 works for me.
Maybe this helps.
By katz
#49297 I have adapted my code so that you can set the number of sliders by changing the variable 'sliderMAX' in line 10. Change this value to experiment with the number of sliders. You don't have to copy chunks of code over and over, you can use for-loops and passing variables in functions to do the job for you. I keep track of all the slidervalues and the ESP-variables in arrays (check line 11).
This works fine on my computer. I have tried it with 50 sliders and it still renders the website just fine. But remember that in Ajax, the variables are written to or retrieved from the XML-file and that takes time. If the number of sliders is big, the blinking of the led gets irregular (remember that my led is on pin 16, yours may be on another pin. Check line 9). I think the speed of your computer limits the number of variables (sliders) it can handle.
Enjoy, Peter.
#include <ESP8266WebServer.h>
ESP8266WebServer server(80);
const char* ssid="yourSSID";
const char* password="yourPASSWORD";
String webSite,javaScript,XML;
unsigned long wait000=0UL,wait001=1000UL;
int LED=16;
const int sliderMAX=10;                         // This sets the number of sliders you want
int sliderVal[sliderMAX]={60},ESPval[sliderMAX];
void buildWebsite(){
  buildJavascript();
  webSite="<!DOCTYPE HTML>\n";
  webSite+="<META name='viewport' content='width=device-width, initial-scale=1'>\n";
  webSite+=javaScript;
  webSite+="<BODY onload='process()'>\n";
  webSite+="<BR>This is the ESP website ...<BR>\n";
  webSite+="Runtime = <A ID='runtime'></A><BR><BR>\n";
  webSite+="<TABLE BORDER=1 style='text-align:center;border-collapse:collapse'>\n";
  for(int i=0;i<sliderMAX;i++){
    webSite+="<TR>\n";
    webSite+="<TD><BR><INPUT ID='slider"+(String)i+"' TYPE='range' ONCHANGE='Slider("+(String)i+")'></TD>\n";  //in Firefox, Chrome and Edge use ONINPUT
    webSite+="<TD>Slidervalue"+(String)i+" = <A ID='Sliderval"+(String)i+"'></A><BR>\n";
    webSite+="ESPval"+(String)i+" = <A ID='ESPval"+(String)i+"'></A> milliseconds</TD>\n";
    webSite+="</TR>\n";
  webSite+="</TABLE>\n";
  webSite+="</BODY>\n";
  webSite+="</HTML>\n";
void buildJavascript(){
  javaScript="<SCRIPT>\n";
  javaScript+="xmlHttp=createXmlHttpObject();\n";
  javaScript+="function createXmlHttpObject(){\n";
  javaScript+="  if(window.XMLHttpRequest){\n";
  javaScript+="    xmlHttp=new XMLHttpRequest();\n";
  javaScript+="  }else{\n";
  javaScript+="    xmlHttp=new ActiveXObject('Microsoft.XMLHTTP');\n";
  javaScript+="  }\n";
  javaScript+="  return xmlHttp;\n";
  javaScript+="}\n";
  javaScript+="function process(){\n";
  javaScript+="  if(xmlHttp.readyState==0||xmlHttp.readyState==4){\n";
  javaScript+="    xmlHttp.onreadystatechange=function(){\n";
  javaScript+="      if(xmlHttp.readyState==4&&xmlHttp.status==200){\n";
  javaScript+="        xmlDoc=xmlHttp.responseXML;\n";
  javaScript+="        xmlmsg=xmlDoc.getElementsByTagName('millistime')[0].firstChild.nodeValue;\n";
  javaScript+="        document.getElementById('runtime').innerHTML=xmlmsg;\n";
  javaScript+="        for(i=0;i<"+(String)sliderMAX+";i++){\n";
  javaScript+="          xmlmsg=xmlDoc.getElementsByTagName('sliderval'+i)[0].firstChild.nodeValue;\n";
  javaScript+="          document.getElementById('slider'+i).value=xmlmsg;\n";
  javaScript+="          document.getElementById('Sliderval'+i).innerHTML=xmlmsg;\n";
  javaScript+="          xmlmsg=xmlDoc.getElementsByTagName('ESPval'+i)[0].firstChild.nodeValue;\n";
  javaScript+="          document.getElementById('ESPval'+i).innerHTML=xmlmsg;\n";
  javaScript+="        }\n";
  javaScript+="      }\n";
  javaScript+="    }\n";
  javaScript+="    xmlHttp.open('PUT','xml',true);\n";
  javaScript+="    xmlHttp.send(null);\n";
  javaScript+="  }\n";
  javaScript+="  setTimeout('process()',1000);\n";
  javaScript+="}\n";
  javaScript+="function Slider(cnt){\n";
  javaScript+="  sliderVal=document.getElementById('slider'+cnt).value;\n";
  javaScript+="  document.getElementById('Sliderval'+cnt).innerHTML=sliderVal;\n";
  javaScript+="  document.getElementById('ESPval'+cnt).innerHTML=9*(100-sliderVal)+100;\n";
  javaScript+="    xmlHttp.open('PUT','setESPval?cnt='+cnt+'&val='+sliderVal,true);\n";
  javaScript+="  }\n";
  javaScript+="}\n";
  javaScript+="</SCRIPT>\n";
void buildXML(){
  XML="<?xml version='1.0'?>";
  XML+="<xml>";
  XML+="<millistime>";
  XML+=millis2time();
  XML+="</millistime>";
    XML+="<sliderval"+(String)i+">";
    XML+=String(sliderVal[i]);
    XML+="</sliderval"+(String)i+">";
    XML+="<ESPval"+(String)i+">";
    ESPval[i]=9*(100-sliderVal[i])+100;
    XML+=String(ESPval[i]);
    XML+="</ESPval"+(String)i+">";
  XML+="</xml>";
String millis2time(){
  String Time="";
  unsigned long ss;
  byte mm,hh;
  ss=millis()/1000;
  hh=ss/3600;
  mm=(ss-hh*3600)/60;
  ss=(ss-hh*3600)-mm*60;
  if(hh<10)Time+="0";
  Time+=(String)hh+":";
  if(mm<10)Time+="0";
  Time+=(String)mm+":";
  if(ss<10)Time+="0";
  Time+=(String)ss;
  return Time;
void handleWebsite(){
  buildWebsite();
  server.send(200,"text/html",webSite);
void handleXML(){
  buildXML();
  server.send(200,"text/xml",XML);
void handleESPval(){
  int sliderCNT=server.arg("cnt").toInt();
  sliderVal[sliderCNT]=server.arg("val").toInt();
  buildXML();
  pinMode(LED,OUTPUT);
  WiFi.begin(ssid,password);
  while(WiFi.status()!=WL_CONNECTED)delay(500);
  WiFi.mode(WIFI_STA);
  Serial.println("\n\nBOOTING ESP8266 ...");
  Serial.println(ssid);
  Serial.print("Station IP address: ");
  server.on("/",handleWebsite);
  server.on("/xml",handleXML);
  server.on("/setESPval",handleESPval);
  server.begin();
  server.handleClient();
  if(millis()>wait000){
    buildXML();
    wait000=millis()+1000UL;
  if(millis()>wait001){
    digitalWrite(LED,!digitalRead(LED));
    wait001=millis()+ESPval[0];
By mrburnette
#51111
eqsOne wrote:Thanks Peter for this awesome sketch. Just added this to my ESP/TrinketPro BBQ-Thermomter, which makes the temerature now showing without having to refresh the whole site all the time.
You may also want to play around with webSockets in my project for Remote Temperature which is a grind of code originally put together by markingle.
Ray
