By Rudolf
#35818
martinayotte wrote:From the above code, the include should simply be "ESP8266WiFi.h"
Thank you martinayotte for your help.
Unfortunately that was not all to make it work. Following the working recipe:
// start telnet server (do NOT put in setup())
const uint16_t aport = 23; // standard port
WiFiServer TelnetServer(aport);
WiFiClient TelnetClient;
  TelnetServer.begin();
  TelnetServer.setNoDelay(true);
} // setup()
//  on another computer start your Telnet client with connect to NodeMCU
//  example: telnet 192.168.4.1
  // send info to Telnet
  if (!TelnetClient) {  // otherwise it works only once
        TelnetClient = TelnetServer.available();
  if (TelnetClient.connected()) {
    TelnetClient.println("Telnet Test");
This Telnet client is very good usable to replace the Serial Monitor in some cases.
Regards, Rudolf
