By laxmimerit
#39090 MY esp modules tcp transmission is very slow. please refer the following code
Code: Select allvoid loop(void) {
  if (!serverClient.connected()) {
    delay(100);
    serverClient = server.available();
    if (serverClient.connected()) {
      int adc = analogRead(A0);
      Serial.write("\nwaiting for input");
      String line = serverClient.readStringUntil('\n');
      Serial.write("\nSending ADC value to client");
      line = String(adc);                               // if I comment this line, its speed is much enough to gain 50 sample/second
      serverClient.println(line);
      Serial.write("\nADC Value sent");
      delay(100);
But if I comment " line = String(adc) ", i.e. if I return same value what I received it boost its speed. what could be possible mistakes.
P.S. TCP client program is working fine, I have tested that client program with server written in lua language.
By martinayotte
#39098 That's really strange that a simple Integer to String conversion slow the whole TCP transmission ... :?
But why are you doing the "String line = serverClient.readStringUntil('\n');" call if you only wish to send something ?
This is waiting for the client to send CR each time before continue in your loop, so the latency your see is probably some kind of timeout.
By WereCatf
#39099
martinayotte wrote:That's really strange that a simple Integer to String conversion slow the whole TCP transmission ... :?
It's not the conversion, it's the length of the resulting string that causes the issue, something to do with the TCP-packet buffer length. What's the length of the string before the conversion, ie. the length of the data read from the client? I read about this elsewhere, but I forget where, and the solution for now seems to be padding the outgoing data with extra content, like e.g. space characters.
By laxmimerit
#39100
If it is timeout then why it is working fine when I am sending back same signal what I receive. any suggestion ?
