By unicorns4lyf
#40239 I have an ESP-01 module connected to the arduino and powered by an external power source. I tried sending AT commands using the serial monitor in Arduino IDE, blue led blinks each time I send a command, but I get no response back.
ESP --- Power
Vcc --- 3.3v
GND --- GND
ESP --- Arduino UNO
GND --- GND
CH_PD --- 3.3v (tied 10kOhm)
RX --- RX (connected 10kOhm to GND and RX Arduino)
TX --- TX
I tried swapping the TX and RX pins, directly connecting the pins without resistors, or even connecting the other pins to either 3.3v or GND like other tutorials schematics. I also tried uploading the BareMinimum code or SoftSerial samples provided by other tutorials. In the end, nothing works.
Also when I try to upload code to the ESP-01 through the IDE I get "warning: espcomm_sync failed error: espcomm_open failed" errors.
Is my module fried or am I doing something wrong?
By unicorns4lyf
#40891
vipinchandras wrote:what baud rate are you setting in arduino serial monitor to communicate with esp-01? Try 115200 or 9600.
I tried rewiring to get something and 74880 is the only rate that works for me now, the rest just spits out garbled characters. Now when I put CH_PD to HIGH, I get "Fatal exception (0): epc1=0x40217c4c, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000"
