Build script updated: https://gist.github.com/fpoussin/7ae55b5a5bd9a28ce21d
Now with C++ thanks to jcmvbkbc's newlib
![Smile :)](./images/smilies/icon_e_smile.gif)
Explore... Chat... Share...
zarya wrote:i wrote up a guide on getting the compiler to work
its for ubuntu 12.04 32-bit and you can find it here https://nurdspace.nl/ESP8266/First_setup
[INFO ] Installing cross-gdb
[ERROR] configure: error: expat is missing or unusable
[ERROR] make[2]: *** [configure-gdb] Error 1
[ERROR] make[1]: *** [all] Error 2
[ERROR]
[ERROR] >>
[ERROR] >> Build failed in step 'Installing cross-gdb'
[ERROR] >> called in step '(top-level)'
[ERROR] >>
[ERROR] >> Error happened in: CT_DoExecLog[scripts/functions@257]
[ERROR] >> called from: do_debug_gdb_build[scripts/build/debug/300-gdb.sh@174]
[ERROR] >> called from: do_debug[scripts/build/debug.sh@35]
[ERROR] >> called from: main[scripts/crosstool-NG.sh@638]
[ERROR] >>
[ERROR] >> For more info on this error, look at the file: 'build.log'
[ERROR] >> There is a list of known issues, some with workarounds, in:
[ERROR] >> 'share/doc/crosstool-ng/ct-ng.1.20.0/B - Known issues.txt'
[ERROR]
[ERROR] (elapsed: 13:08.55)
[13:09] / make: *** [build] Error 2
ystrem wrote:[ERROR] configure: error: expat is missing or unusable
