I've built the esp-open-sdk (after having to enlarge the VM's disk to fit the build). I tried to build it standalone and not.
I'm still getting link errors:
[LD] images/antares.elf
/home/esp8266/src/esp-open-sdk/xtensa-lx106-elf/lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: cannot find -lmain
/home/esp8266/src/esp-open-sdk/xtensa-lx106-elf/lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: cannot find -lnet80211
/home/esp8266/src/esp-open-sdk/xtensa-lx106-elf/lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: cannot find -lphy
/home/esp8266/src/esp-open-sdk/xtensa-lx106-elf/lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: cannot find -lpp
/home/esp8266/src/esp-open-sdk/xtensa-lx106-elf/lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: cannot find -lwpa
/home/esp8266/src/esp-open-sdk/xtensa-lx106-elf/lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: cannot find -lssl
/home/esp8266/src/esp-open-sdk/xtensa-lx106-elf/lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: cannot find -llwip
make: *** [images/antares.elf] Error 1
Should I build the esp-open-sdk standalone or not?
What exactly is Antares and how does it relate to Franekstein?
Should I be building this in the sdk's app directory? I didn't have to before.
How do I get Frankenstein to use the esp-open-sdk SDK libraries? They are in /home/esp8266/src/esp-open-sdk/sdk/lib.
I tried adding:
CONFIG_LDFLAGS="-L/home/esp8266/src/esp-open-sdk/sdk/lib"
manually to .config in esp8266-frankenstein to no avail.
Could you please give detailed build instructions on a fresh system? Thanks. I don't know what I'm missing.
I've added COMMON_LDFLAGS="-L/opt/Espressif/esp_iot_sdk_v0.9.2/lib/" to the top Makefile, it makes ld find most of the libs...
But still /opt/Espressif/crosstool-NG/builds/xtensa-lx106-elf/lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: cannot find -lpp
In fact, no libpp in 0.9.2 libs... There's one in 0.9.3. Is Antares to be build against 0.9.3?
Vincent
My system is a native 64 bits archlinux...
make STANDALONE=y
'Standalone' build places all libraries and headers into the toolchain itself, so you need no additional magic.
Antares is my buildsystem+library code I use for all embedded projects. Since kconfig/menuconfig requires a plenty of makefile magic to use properly, so I made antares in a way so that I can reuse it for every project with zero effort.
For frankenstein it only provides (for now) menuconfig/nconfig targets and a few library code snipplets from there.
I've added a README.hacking to the repo with detailed instructions on setting up build environment. I should've done that it in the first place, sorry. Hope it helps.
