By CARPP
#58968 If i try to build my project, i get this output:
xtensa-lx106-elf-gcc -Teagle.app.v6.ld segmentled.o -nostdlib -Wl,--start-group -lmain -lnet80211 -lwpa -llwip -lpp -lphy -lc -Wl,--end-group -lgcc -o segmentled
/home/test/Desktop/opt/esp-open-sdk/xtensa-lx106-elf/lib/gcc/xtensa-lx106-elf/4.8.5/../../../../xtensa-lx106-elf/bin/ld: segmentled section `.text' will not fit in region `iram1_0_seg'
/home/test/Desktop/opt/esp-open-sdk/xtensa-lx106-elf/lib/gcc/xtensa-lx106-elf/4.8.5/../../../../xtensa-lx106-elf/bin/ld: region `iram1_0_seg' overflowed by 1000 bytes
<builtin>: recipe for target 'segmentled' failed
make: *** [segmentled] Error 1
does anyone know what i do wrong or what causes this error? Any help would be very much appreciated! :)
By davydnorris
#58981 Have a look at my thread on building the ESP toolchain - it could be that you are using the libgcc that is built with the tools rather than the one in the SDK, and this contains functions that are in the ESP ROM. I have created a script to remove them from the library, or you can use the supplied SDK libgcc
By CARPP
#59022 Okay, the solution was to copy the libgcc.a file from:
esp-open-sdk/ESP8266_NONOS/lib/
to
Now everything is working fine! I can't believe it... :D
