By niceskylei
#9381 hi,all:
I had try serval time to build esp8266 corss compiler on Mac OS Yosemite follow the http://tuanpm.net/post/109019196894/esp8266-development-kit-on-mac-os-yosemite-and,unluckly encounter errors.
first time build error:
Code: Select all[INFO ]  Installing binutils for host
[ERROR]    /Volumes/ESPTools/esp-open-sdk/crosstool-NG/.build/src/binutils-2.24/gas/as.c:224:14: error: use of undeclared identifier 'TARGET_ALIAS'
[ERROR]    /Volumes/ESPTools/esp-open-sdk/crosstool-NG/.build/src/binutils-2.24/gas/as.c:635:5: error: use of undeclared identifier 'TARGET_ALIAS'
[ERROR]    /Volumes/ESPTools/esp-open-sdk/crosstool-NG/.build/src/binutils-2.24/gas/as.c:648:40: error: use of undeclared identifier 'TARGET_ALIAS'
[ERROR]    /Volumes/ESPTools/esp-open-sdk/crosstool-NG/.build/src/binutils-2.24/gas/as.c:649:44: error: use of undeclared identifier 'TARGET_CANONICAL'
[ERROR]    /Volumes/ESPTools/esp-open-sdk/crosstool-NG/.build/src/binutils-2.24/gas/as.c:650:43: error: use of undeclared identifier 'TARGET_CPU'
[ERROR]    make[7]: *** [as.o] Error 1
[ERROR]    make[6]: *** [all-recursive] Error 1
[ERROR]    make[5]: *** [all] Error 2
[ERROR]    make[4]: *** [all-gas] Error 2
[ERROR]    make[3]: *** [all] Error 2
[ERROR]
[ERROR]  >>
[ERROR]  >>  Build failed in step 'Installing binutils for host'
[ERROR]  >>        called in step '(top-level)'
[ERROR]  >>
[ERROR]  >>  Error happened in: CT_DoExecLog[scripts/functions@216]
[ERROR]  >>        called from: do_binutils_backend[scripts/build/binutils/binutils.sh@233]
[ERROR]  >>        called from: do_binutils_for_host[scripts/build/binutils/binutils.sh@98]
[ERROR]  >>        called from: main[scripts/crosstool-NG.sh@638]
[ERROR]  >>
[ERROR]  >>  For more info on this error, look at the file: 'build.log'
[ERROR]  >>  There is a list of known issues, some with workarounds, in:
[ERROR]  >>      'share/doc/crosstool-ng/ct-ng.1.20.0/B - Known issues.txt'
[ERROR]
[ERROR]  (elapsed: 7:45.99)
[07:46] / make[2]: *** [build] Error 1
make[1]: *** [_toolchain] Error 2
make: *** [/esptools/esp-open-sdk/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc] Error 2
rebuild error:
Code: Select allmake -C crosstool-NG -f ../Makefile _toolchain
./ct-ng xtensa-lx106-elf
  CONF  config/config.in
# configuration saved
Initially reported by: Max Filippov <jcmvbkbc@gmail.com>
URL: http://www.esp8266.com/viewtopic.php?f=9&t=224
WARNING! This sample may enable experimental features.
         Please be sure to review the configuration prior
         to building and using your toolchain!
Now, you have been warned!
Now configured for "xtensa-lx106-elf"
sed -r -i.org s%CT_PREFIX_DIR=.*%CT_PREFIX_DIR="/esptools/esp-open-sdk/xtensa-lx106-elf"% .config
sed -r -i s%CT_INSTALL_DIR_RO=y%"#"CT_INSTALL_DIR_RO=y% .config
cat ../crosstool-config-overrides >> .config
./ct-ng build
[INFO ]  Performing some trivial sanity checks
[INFO ]  Build started 20150210.172739
[INFO ]  Building environment variables
[00:01] / stat: cannot read file system information for '%Lp': No such file or directory
[ERROR]
[ERROR]  >>
[ERROR]  >>  Build failed in step '(top-level)'
[ERROR]  >>
[ERROR]  >>  Error happened in: CT_DoForceRmdir[scripts/functions@460]
[ERROR]  >>        called from: main[scripts/crosstool-NG.sh@238]
[ERROR]  >>
[ERROR]
[ERROR]  (elapsed: 0:00.43)
[00:01] / make[2]: *** [build] Error 1
I had fix secend build error,by modify "scripts/functions" file.
the first build error still can't fix it. follow the instructions I had installed binutils,but why still install binutils when make?how do I config it?
By williamjf77
#9468 I think osx uses the built in versions of grep and gperf so I had to point the build to use the gnu versions installed through ma ports , there is a tutorial somewhere that worked for me , I'll try to find it , but try using $grep=/path/to/grep before you run the build
