Re: Using GCC to program the ESP8266
Posted: Thu Sep 04, 2014 11:01 am
As far as I can see, that script is needed but doesn't solve the problem: due to some braindeadness the crosstool-ng still won't pick it up. I hacked it to pick it up anyway:
but that gives other problems: the compiler now spits out instructions binutils assembler doesn't understand.
diff --git a/scripts/build/arch/xtensa.sh b/scripts/build/arch/xtensa.sh
index 09a27a2..2c46bab 100644
--- a/scripts/build/arch/xtensa.sh
+++ b/scripts/build/arch/xtensa.sh
@@ -22,7 +22,6 @@ CT_ConfigureXtensa() {
custom_overlay="xtensa-overlay.tar"
fi
- local full_file="${CT_TARBALLS_DIR}/${custom_overlay}"
local basename="${component}-${version}"
local ext
@@ -34,24 +33,31 @@ CT_ConfigureXtensa() {
custom_location="${CT_CUSTOM_LOCATION_ROOT_DIR}"
fi
- if ! ext="$(CT_GetFileExtension "${basename}")"; then
- CT_DoLog WARN "'${basename}' not found in '${CT_TARBALLS_DIR}'"
- return 1
- fi
+ #From here on, ${custom_location}/${custom_overlay} should point to the overlay file.
+ local full_file="${custom_location}/${custom_overlay}"
- if [ -e "${CT_SRC_DIR}/.${basename}.configuring" ]; then
- CT_DoLog ERROR "The '${basename}' source were partially configured."
- CT_DoLog ERROR "Please remove first:"
- CT_DoLog ERROR " - the source dir for '${basename}', in '${CT_SRC_DIR}'"
- CT_DoLog ERROR " - the file '${CT_SRC_DIR}/.${basename}.extracted'"
- CT_DoLog ERROR " - the file '${CT_SRC_DIR}/.${basename}.patch'"
- CT_DoLog ERROR " - the file '${CT_SRC_DIR}/.${basename}.configuring'"
- CT_Abort
- fi
+ #No idea. - JD
+# if ! ext="$(CT_GetFileExtension "${basename}")"; then
+# CT_DoLog WARN "'${basename}' not found in '${CT_TARBALLS_DIR}'"
+# return 1
+# fi
+ #This seems to always trigger during a normal run. Commented out for now. -JD
+# if [ -e "${CT_SRC_DIR}/.${basename}.configuring" ]; then
+# CT_DoLog ERROR "(xtensa.sh) The '${basename}' source were partially configured."
+# CT_DoLog ERROR "Please remove first:"
+# CT_DoLog ERROR " - the source dir for '${basename}', in '${CT_SRC_DIR}'"
+# CT_DoLog ERROR " - the file '${CT_SRC_DIR}/.${basename}.extracted'"
+# CT_DoLog ERROR " - the file '${CT_SRC_DIR}/.${basename}.patch'"
+# CT_DoLog ERROR " - the file '${CT_SRC_DIR}/.${basename}.configuring'"
+# CT_Abort
+# fi
- CT_DoLog EXTRA "Using '${custom_config}' from ${custom_location}"
- CT_DoExecLog DEBUG ln -sf "${custom_location}/${custom_config}" \
- "${CT_TARBALLS_DIR}/${custom_config}"
+ CT_DoLog EXTRA "Using '${custom_overlay}' from ${custom_location}"
+ #Is this good for anything? -JD
+# CT_DoExecLog DEBUG ln -sf "${custom_location}/${custom_overlay}" \
+# "${CT_TARBALLS_DIR}/${custom_overlay}"
CT_DoExecLog DEBUG touch "${CT_SRC_DIR}/.${basename}.configuring"
@@ -60,16 +66,16 @@ CT_ConfigureXtensa() {
tar_opts=( "--strip-components=1" )
tar_opts+=( "-xv" )
- case "${ext}" in
- .tar) CT_DoExecLog FILE tar "${tar_opts[@]}" -f "${full_file}" "${component}";;
- .tar.gz|.tgz) gzip -dc "${full_file}" | CT_DoExecLog FILE tar "${tar_opts[@]}" -f - "${component}";;
- *) CT_DoLog WARN "Don't know how to handle '${basename}${ext}': unknown extension"
+ case "${full_file}" in
+ *.tar) CT_DoExecLog FILE tar "${tar_opts[@]}" -f "${full_file}" "${component}";;
+ *.tar.gz|.tgz) gzip -dc "${full_file}" | CT_DoExecLog FILE tar "${tar_opts[@]}" -f - "${component}";;
+ *) CT_DoLog WARN "Don't know how to handle '${full_file}': '${ext}': unknown extension"
return 1
esac
- CT_DoExecLog DEBUG touch "${CT_SRC_DIR}/.${basename}.configured"
- CT_DoExecLog DEBUG rm -f "${CT_SRC_DIR}/.${basename}.configuring"
+# CT_DoExecLog DEBUG touch "${CT_SRC_DIR}/.${basename}.configured"
+# CT_DoExecLog DEBUG rm -f "${CT_SRC_DIR}/.${basename}.configuring"
CT_Popd
diff --git a/scripts/build/binutils/binutils.sh b/scripts/build/binutils/binutils.sh
index 5d3734f..dafbb6a 100644
--- a/scripts/build/binutils/binutils.sh
+++ b/scripts/build/binutils/binutils.sh
@@ -38,7 +38,7 @@ do_binutils_extract() {
CT_Patch "elf2flt" "${CT_ELF2FLT_VERSION}"
fi
- if [ -n "${CT_ARCH_XTENSA_CUSTOM_NAME}" ]; then
+ if [ -n "${CT_XTENSA_CUSTOM}" ]; then
CT_ConfigureXtensa "binutils" "${CT_BINUTILS_VERSION}"
fi
diff --git a/scripts/build/cc/gcc.sh b/scripts/build/cc/gcc.sh
index e0b0e8e..fcb47b9 100644
--- a/scripts/build/cc/gcc.sh
+++ b/scripts/build/cc/gcc.sh
@@ -59,7 +59,7 @@ do_cc_extract() {
CT_DoExecLog ALL cp -v "${CT_TARBALLS_DIR}/ecj-latest.jar" "${CT_SRC_DIR}/gcc-${CT_CC_VERSION}/ecj.jar"
fi
CT_ConfigureXtensa "gcc" "${CT_CC_VERSION}"
fi
diff --git a/scripts/build/debug/300-gdb.sh b/scripts/build/debug/300-gdb.sh
index b10f910..7bc33b8 100644
--- a/scripts/build/debug/300-gdb.sh
+++ b/scripts/build/debug/300-gdb.sh
@@ -94,7 +94,7 @@ do_debug_gdb_extract() {
CT_Patch "expat" "${CT_DEBUG_GDB_EXPAT_VERSION}"
fi
- if [ -n "${CT_ARCH_XTENSA_CUSTOM_OVERLAY_FILE}" ]; then
CT_ConfigureXtensa "gdb" "${CT_GDB_VERSION}"
fi
