LD build/esp8266_at.out
build/esp8266_at_app.a(user_webserver.o): In function `webserver_recon':
user_webserver.c:(.irom0.text+0xc8): undefined reference to `jsonparse_strcmp_value'
build/esp8266_at_app.a(user_webserver.o): In function `wifi_softap_set':
/home/noel/esp_sources/IoT_Demo/user/user_webserver.c:486: undefined reference to `jsonparse_strcmp_value'
build/esp8266_at_app.a(user_webserver.o): In function `device_get':
/home/noel/esp_sources/IoT_Demo/user/user_webserver.c:49: undefined reference to `jsontree_path_name'
And a couple more refering to undefines refernce to `espconn_secure_*....'
So obviously I'm missing a reference to a json lib, but not quite sure where.
Thanks!
noelportugal wrote:Help anyone? I am able to compile the AT example but when I try to compile the IoT_Demo I get a lot of the following undefined references:
Thanks!
Can you share the makefile you are using?
Make sure you link against json and ssl libraries from the SDK.
Now, in the eagle_soc.h include file, the base address to the GPIO registers is given as 0x6000.0300, and indeed, using the registers in that range (0x6000.0304, 0x6000.0308, 0x6000.0310 and 0x6000.0314) that allows direct access. However, putting the dump of the internal ROM into IDA, and looking at the disassembly for the "gpio_output_set" function, gives this code:
ROM:40004CD0 gpio_output_set: ; CODE XREF: gpio_init+26p
ROM:40004CD0 ; gpio_intr_test+17p ...
ROM:40004CD0 l32r a6, dword_40000FC4
ROM:40004CD3 memw
ROM:40004CD6 s32i a2, a6, 4
ROM:40004CD9 memw
ROM:40004CDC s32i a3, a6, 8
ROM:40004CDF memw
ROM:40004CE2 s32i a4, a6, 0x10
ROM:40004CE5 memw
ROM:40004CE8 s32i a5, a6, 0x14
ROM:40004CEB ret.n
ROM:40004CEB ; End of function gpio_output_set
The value at dword_40000FC4 is 0x6000.0200. Strange thing is that calling this function works as expected, while accessing the registers in that range (which would end up as 0x6000.0204, 0x6000.0208, 0x6000.0210 and 0x6000.0214, if i am reading the code right) causes an exception.
What am i missing here? Is there something else going on that will add an offset of 0x100 to end up at the right address? Or does the plugin interpret a few things wrongly? The stored dword in the ROM for the base is really 0x6000.0200, i double cheecked.
Greetings,
Chris
