By jcmvbkbc
#2263
karcheng wrote:Unable to find headers when I compile
/opt/Espressif/xtensa-lx106-elf/xtensa-lx106-elf/include/c++/4.8.2/cwchar:142:11: error: '::fgetwc' has not been declared
using ::fgetwc;
/opt/Espressif/xtensa-lx106-elf/xtensa-lx106-elf/include/c++/4.8.2/cwchar:143:11: error: '::fgetws' has not been declared
using ::fgetws;
Humm... The headers are fine, but the function declarations are missing.
That must be caused by the last step when you tar -xvzf include.tgz into the compiler directory.
Compilation passes for me when I use g++ built by crosstool-NG without all the additional steps like 'adding SDK libs' and 'adding header files'.
What if you skip the last step and also skip copying libc.a?
By joostn
#2560 Hi,
I'm trying to compile a c++ application for the ESP8266. I've set up g++ through 'git clone -b lx106-g++' as explained above.
It's mostly working, except for the fact that constructors of global objects are not being called. For example:
Code: Select allclass TestClass
public:
   TestClass()
      : m_a(5) {}
   int m_a;
TestClass tc;
extern "C" void user_init(void)
 // if I print tc.m_a here, it will show 0 instead of 5.
These are my compiler and linker options:
Code: Select all"/opt/Espressif/crosstool-NG/builds/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++"  -Wl,-EL -nostdlib -mlongcalls -mtext-section-literals -D__ets__ -DICACHE_FLASH -fmessage-length=0 -fverbose-asm -ffunction-sections -fdata-sections  -Iinclude -I../../esp8266/esp_iot_sdk_V0.9.2/include/ -I../../cppcomponents/ -Wall -Wundef -Wno-unused-local-typedefs -Wextra -Wno-unused-parameter -Wno-unused-variable -Wno-unused-but-set-variable -Werror=return-type -Wpointer-arith -D_NDEBUG -O3 --std=c++11 -ftree-ter -Wno-reorder -fno-rtti -fno-exceptions -fno-unwind-tables -fno-threadsafe-statics -fno-stack-protector -c -o build/obj/main.o user/main.cpp
AR build/test1_app.a
LD build/test1.out1
"/opt/Espressif/crosstool-NG/builds/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc" -L../../esp8266/esp_iot_sdk_V0.9.2/lib -L ../../esp8266/esp_iot_sdk_V0.9.2/ld/ -Teagle.app.v6.ld -Wl,--no-check-sections -u call_user_start -Wl,-static -nostdlib  -Xlinker -Map=build/test1.map -Wl,--gc-sections -Wl,--start-group -lc -lgcc -lhal -lphy -lnet80211 -llwip -lwpa -lmain -lupgrade  build/test1_app.a -Wl,--end-group -o build/test1.out1
If I omit -nostdlib and use -nodefaultlibs, the linker complains about crt1-sim.o and _vectors.o missing.
Can anyone help me out? BTW I don't need the C++ standard libraries, I just need to be able to work with my own C++ classes.
Thanks!
By Squonk
#2577 Take a look here:
https://github.com/qca/open-ath9k-htc-f ... s/src/xtos
It looks like there are sources for both crt1-sim.o and _vectors.o
However, even if you don't care about C++ standard libraries, it looks like you are missing some pre-main code to initialize the global objects.
By jcmvbkbc
#2579
joostn wrote:It's mostly working, except for the fact that constructors of global objects are not being called.
Right, these constructors are normally called from crtbegin.o/crtend.o, but looks like we should be able to call them ourselves from the user_main.
joostn wrote:If I omit -nostdlib and use -nodefaultlibs, the linker complains about crt1-sim.o and _vectors.o missing.
Right, these defaults are hard-coded in the gcc. We don't need them, because we're not building for sim and exception vector handlers are in the ROM.
joostn wrote:Can anyone help me out? BTW I don't need the C++ standard libraries, I just need to be able to work with my own C++ classes.
Let me look a bit more at our startup sequence...
