tiawild wrote:Hi!
I'm trying to build the last NodeMCU firmware.
I can make the version in the example folder (Espressif\examples\nodemcu-firmware\) but not the last downloaded (v1.4) because when I try, compiler tells me:Code: Select alluser_exceptions.c:111:5: error: implicit declaration of function '__real__xtos_set_exception_handler' [-Werror=implicit-function-declaration]
__real__xtos_set_exception_handler (cause, fn);
What is wrong ?
Thanks for your help
You can remove the flag "-Werror" from the makefile so as not let the compiler treating warnings as errors
