As per http://nodemcu.readthedocs.io/en/latest ... ng-started: build the firmware, flash it, then upload Lua code.
Good luck and welcome to the NodeMCU universe.
Explore... Chat... Share...
There's a link to the docs just in case in one of my previous comments. Use esptool.py and study http://nodemcu.readthedocs.io/en/latest ... g-firmware.
Note:
The address for esp_init_data_default.bin depends on the size of your module's flash. ESP-01, -03, -07 etc. with 512 kByte flash require 0x7c000. Init data goes to 0x3fc000 on an ESP-12E with 4 MByte flash.
NodeMCU 0.9.6 build 20150704 powered by Lua 5.1.4
lua: cannot open init.lua
