As a newbie I am trying to figure out how to use DS18B20.lua.
Is this the correct direction?
https://github.com/nodemcu/nodemcu-firmware/tree/master/lua_modules/ds18b20
Thanks!
Best regards,
Fred
Explore... Chat... Share...
t = require("ds18b20")
-- Set module name as parameter of require
local modname = ...
local M = {}
_G[modname] = M
-- Get temperature of first detected sensor in Fahrenheit
print("Temperature: "..t.read(nil,t.F).."'F")
require("ds18b20")
ds18b20.setup(pin)
addrs = ds18b20.addrs()
> PANIC: unprotected error in call to Lua API (error loading module 'ds18b20' from file 'ds18b20.lua':
ds18b20.lua:114: malformed number near '1.8')
