By rudy
#64255 For me? Yes. For you? If you are asking then probably not. Do you have a soldering iron? I would use wirewrap wire to join the common connections on the display, on the other side. (not pin side)
But before you get too far into it. Try and connect to the LCD and get that working before trying the touch panel. One piece at a time. Then look at how to integrate both.
