By Andu
#65263 I'm trying to compare every line of the HTTP response to change the state of a relay. I know it's not ideal and there are more elegant ways to do it but for the moment I just need a working prototype to test the module.
the code I have is this:
Code: Select all// Read the entire response and flush it to Serial output
  while(client.available()){
    Serial.print(line);
    if(!strcmp(line.c_str(),"OFF")){
      Serial.println(" -> True");
    } else {
      Serial.println(" ->  False");
-> False is returned for everything
Code: Select allRequest sent - waiting for reply...
HTTP/1.1 200 OK -> False
Content-Type: text/html; charset=UTF-8 -> False
Content-Length: 3 -> False
Date: Tue, 25 Apr 2017 18:02:28 GMT -> False
Accept-Ranges: bytes -> False
Server: LiteSpeed -> False
Connection: close -> False
 -> False
OFF -> False
Connection closed.
By jeffas
#65387 That makes sense. Your client is send CR/LF to terminate lines (as is common in HTTP, indeed mandatory for headers), You are reading each line up to and including the CR, which leaves the NL still in the buffer to be read.
