i currently have problems to connect to my server via tcp. The connection to my local wifi network works fine, but this doesn't work:
LOCAL void ICACHE_FLASH_ATTR
check_ip(void){
struct espconn conn;
struct ip_info ipconf;
uint32_t ipAddr = ipaddr_addr("1.2.3.4");
uint32 localPort = espconn_port();
bool res = wifi_get_ip_info(STATION_IF, &ipconf);
if(!res)
os_printf("No Success.");
else{
if(wifi_station_get_connect_status() == STATION_GOT_IP && ipconf.ip.addr != 0){
os_printf("Got IP Address.\n");
conn.type = ESPCONN_TCP;
conn.state = ESPCONN_NONE;
conn.proto.tcp = (esp_tcp*)os_zalloc(sizeof(esp_tcp));
conn.proto.tcp->local_port = espconn_port();
conn.proto.tcp->remote_port = 80;
os_memcpy(conn.proto.tcp->remote_ip,&ipAddr,4);
espconn_regist_connectcb(&conn,tcp_connect_cb);
espconn_regist_reconcb(&conn,tcp_recon_cb);
espconn_connect(&conn);
os_timer_disarm(&timer);
} else {
os_timer_setfn(&timer,(os_timer_func_t*)check_ip,NULL);
os_timer_arm(&timer,100,0); //recall function after 100ms, don't repeat
This is the error i get on the serial terminal:
Fatal exception 9(LoadStoreAlignmentCause):
epc1=0x4026023f, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000011, depc=0x00000000
Any help is very much appreciated!
