I found a post that showed the UART Tx lines act as antennas when not connected to a serial line, and they added pull up resistors to the Tx lines of both UART0 and UART1.
I did the same with my custom circuit and have noticed my connection is now SOOO much faster and rock solid. Definitely worth a try.
Having said that, if you cannot use a static IP and have a slow DHCP server then your problem may not be internal and out of your control.
