By nqdanyb
#67505
martinayotte wrote:Simply add new handlers for that new URL, and add buttons to webpage which have onClick calling some Ajax with those URL :
Code: Select allserver.on("/gpio-high", handleGPIO_HIGH);
server.on("/gpio-low", handleGPIO_LOW);
I tried to try a button to turn the led on or off but when the led on or off webpage
was not updated the temperature and humidity information, help me. I'm not good at html
#include <ESP8266WebServer.h>
#include <DHT.h>
ESP8266WebServer server(80);
const char* ssid="F1T1P1";
const char* password="adwchhhhccv21A";
String webSite,javaScript,XML;
unsigned long wait000=0UL,wait001=1000UL;
unsigned long time1 = 0;
// Khai Bao Dimmer Led
// LED FET
#define ledPIN 13
int led_delay = 0;
#define time_at_colour 1200
unsigned long TIME_LED = 0;
int LED, dimled;
int LED_A = 0;
#define INPUT_PIN 14// Cam bien chuyen dong PIR
bool oldInputState;//Cho cam bien PIR
String PIR;
int inputState;
#define DHTPIN 12 // what pin we're connected to
DHT dht;
float h, t, l;
int LED1=4;
int sliderVal=0,blinkSpeed=1000;
void buildJavascript(),cambienDHT22(),cambienAnhSang(),cambienpir(),LED_CHANGE(),handlebatled(),handletatled(),handleblinkled();
String millis2time(){
  String Time="";
  unsigned long ss;
  byte mm,hh;
  ss=millis()/1000;
  hh=ss/3600;
  mm=(ss-hh*3600)/60;
  ss=(ss-hh*3600)-mm*60;
  if(hh<10)Time+="0";
  Time+=(String)hh+":";
  if(mm<10)Time+="0";
  Time+=(String)mm+":";
  if(ss<10)Time+="0";
  Time+=(String)ss;
  return Time;
void buildWebsite(){
  buildJavascript();
  webSite="<!DOCTYPE HTML>\n";
  webSite+="<META name='viewport' content='width=device-width, initial-scale=1'>\n";
  webSite+=javaScript;
  webSite+="<BODY onload='process()'>\n";
  webSite+="<BR>This is the ESP website ...<BR>\n";
  webSite+="Runtime = <A ID='runtime'></A><BR><BR>\n";
webSite+= "<h1>Cam bien</h1>";
webSite+= "Light: <A ID='light'></A><BR><BR>\n";
webSite+= "Tem: <A ID='tem'></A><BR><BR>\n";
webSite+= "Hum: <A ID='hum'></A><BR><BR>\n";
webSite+= "PIR:<A ID='pir'></A><BR><BR>\n";
webSite+= "<hr />";
webSite+= "<h1>Dieu Khien</h1>";
webSite+= "<input type='submit' style='height:10%;width:100px' name='action' ID='led1on' value='Led On'></A><BR><BR>\n";
//webSite+=" Led1on= <A ID='led1on'>0</A><BR>\n";
webSite+= "<input type='submit' style='height:10%;width:100px' name='action' ID='led1off' value='Led Off'></A><BR><BR>\n";
//webSite+=" Led1off= <A ID='led1off'>0</A><BR>\n";
webSite+= "<input type='submit' style='height:10%;width:100px' name='action' ID='led1blink' value='Led Blink'></A><BR>\n";
webSite+="<form action='/led1/1' method='POST'><input style='width:20%; height:10%' type='submit' name='action' value='Led On'></form>\r\n";
webSite+="<form action='/led1/0' method='POST'><input style='width:20%; height:10%' type='submit' name='action' value='Led Off'></form><BR>\n";
  webSite+="<INPUT style='width:100%; height:50px' ID='slider' min='0' max='100' value='0' TYPE='range' ONCHANGE='Slider()'><BR>\n";
  webSite+="Slidervalue = <A ID='Sliderval'>0</A><BR>\n";
  webSite+="Blinkspeed = <A ID='Blinkspeed'></A> milliseconds<BR>\n";
  webSite+="</BODY>\n";
  webSite+="</HTML>\n";
void buildJavascript(){
  javaScript="<SCRIPT>\n";
  javaScript+="xmlHttp=createXmlHttpObject();\n";
  javaScript+="function createXmlHttpObject(){\n";
  javaScript+="  if(window.XMLHttpRequest){\n";
  javaScript+="    xmlHttp=new XMLHttpRequest();\n";
  javaScript+="  }else{\n";
  javaScript+="    xmlHttp=new ActiveXObject('Microsoft.XMLHTTP');\n";
  javaScript+="  }\n";
  javaScript+="  return xmlHttp;\n";
  javaScript+="}\n";
  javaScript+="function process(){\n";
  javaScript+="  if(xmlHttp.readyState==0||xmlHttp.readyState==4){\n";
  javaScript+="    xmlHttp.onreadystatechange=function(){\n";
  javaScript+="      if(xmlHttp.readyState==4&&xmlHttp.status==200){\n";
  javaScript+="        xmlDoc=xmlHttp.responseXML;\n";
  javaScript+="        xmlmsg=xmlDoc.getElementsByTagName('millistime')[0].firstChild.nodeValue;\n";
  javaScript+="        document.getElementById('runtime').innerHTML=xmlmsg;\n";
javaScript+="        xmlmsg=xmlDoc.getElementsByTagName('lightval')[0].firstChild.nodeValue;\n";
javaScript+="        document.getElementById('light').innerHTML=xmlmsg;\n";
javaScript+="        xmlmsg=xmlDoc.getElementsByTagName('temval')[0].firstChild.nodeValue;\n";
javaScript+="        document.getElementById('tem').innerHTML=xmlmsg;\n";
javaScript+="        xmlmsg=xmlDoc.getElementsByTagName('humval')[0].firstChild.nodeValue;\n";
javaScript+="        document.getElementById('hum').innerHTML=xmlmsg;\n";
javaScript+="        xmlmsg=xmlDoc.getElementsByTagName('pirval')[0].firstChild.nodeValue;\n";
javaScript+="        document.getElementById('pir').innerHTML=xmlmsg;\n";
javaScript+="        xmlmsg=xmlDoc.getElementsByTagName('led1on')[0].firstChild.nodeValue;\n";
javaScript+="        document.getElementById('led1on').innerHTML=xmlmsg;\n";
javaScript+="        xmlmsg=xmlDoc.getElementsByTagName('led1off')[0].firstChild.nodeValue;\n";
javaScript+="        document.getElementById('led1off').innerHTML=xmlmsg;\n";
  javaScript+="        xmlmsg=xmlDoc.getElementsByTagName('sliderval')[0].firstChild.nodeValue;\n";
  javaScript+="        document.getElementById('slider').value=xmlmsg;\n";
  javaScript+="        document.getElementById('Sliderval').innerHTML=xmlmsg;\n";
  javaScript+="        xmlmsg=xmlDoc.getElementsByTagName('blinkspeed')[0].firstChild.nodeValue;\n";
  javaScript+="        document.getElementById('Blinkspeed').innerHTML=xmlmsg;\n";
  javaScript+="      }\n";
  javaScript+="    }\n";
  javaScript+="    xmlHttp.open('PUT','xml',true);\n";
  javaScript+="    xmlHttp.send(null);\n";
  javaScript+="  }\n";
  javaScript+="  setTimeout('process()',1000);\n";
  javaScript+="}\n";
  javaScript+="function Slider(){\n";
  javaScript+="  sliderVal=document.getElementById('slider').value;\n";
  javaScript+="  document.getElementById('Sliderval').innerHTML=sliderVal;\n";
  javaScript+="  document.getElementById('Blinkspeed').innerHTML=9*(100-sliderVal)+100;\n";
  javaScript+="    xmlHttp.open('PUT','setBlinkspeed?val='+sliderVal,true);\n";
//javaScript+="    xmlHttp.open('PUT','/led1/1',true);\n";
//javaScript+="    xmlHttp.open('PUT','/led1/0',true);\n";
  javaScript+="  }\n";
  javaScript+="}\n";
  javaScript+="</SCRIPT>\n";
void buildXML(){
  XML="<?xml version='1.0'?>";
  XML+="<xml>";
  XML+="<millistime>";
  XML+=millis2time();
  XML+="</millistime>";
XML+="<lightval>";
XML+=String(l);
XML+="</lightval>";
XML+="<temval>";
XML+=String(t);
XML+="</temval>";
XML+="<humval>";
XML+=String(h);
XML+="</humval>";
XML+="<pirval>";
XML+=PIR;
XML+="</pirval>";
XML+="<led1on>";
XML+="</led1on>";
XML+="<led1off>";
XML+="</led1off>";
  XML+="<sliderval>";
  XML+=String(sliderVal);
  XML+="</sliderval>";
  XML+="<blinkspeed>";
  blinkSpeed=9*(100-sliderVal)+100;
  XML+=String(blinkSpeed);
  XML+="</blinkspeed>";
  XML+="</xml>";
void handleWebsite(){
  buildWebsite();
  server.send(200,"text/html",webSite);
void handleXML(){
  buildXML();
  server.send(200,"text/xml",XML);
void handleBlinkspeed(){
  sliderVal=server.arg("val").toInt();
  buildXML();
void cambienpir(){
//cam bien PIR
  inputState = digitalRead(INPUT_PIN);
  Serial.print("PIR = ");
  Serial.println(inputState);
  if (inputState == HIGH)
    PIR = "Have movement";
  else
    PIR = "No movement";
void cambienDHT22()
  // Use WiFiClient class to create TCP connections for Humidity++++++++++++++++++++++++++
  h = dht.getHumidity();
  Serial.print("Hum from DHT = ");
  Serial.println(h);
  if (isnan(h)) {
    //Serial.println("Failed to read from DHT sensor!");
    return;
  delay(50);
  // Use WiFiClient class to create TCP connections for Temperature
 t = dht.getTemperature();
  Serial.print("Tem from DHT = ");
  Serial.println(t);
  delay(50);
    while(client1.available()){
    String line = client1.readStringUntil('\r');
    Serial.print(line);
   while(client2.available()){
    String line = client2.readStringUntil('\r');
    Serial.print(line);
void cambienAnhSang()
  l = analogRead(A0);// đọc giá trị quang trở
  Serial.print("Light = ");
  Serial.println(l);
   if (isnan(l)) {
    //Serial.println("Failed to read from light sensor!");
    return;
  delay(50);
   while(client3.available()){
    String line = client3.readStringUntil('\r');
    Serial.print(line);
void LED_CHANGE()
  if(LED != LED_A){
    if(LED_A > LED) LED_A = LED_A - 1;
    if(LED_A < LED) LED_A++;
    analogWrite(ledPIN, LED_A);
void handlebatled() {
  digitalWrite(LED1,HIGH);
  int led1stay = digitalRead(LED1);
  Serial.print("LED1 = ");
  Serial.println(led1stay);
  handleWebsite();
  handleXML();
void handletatled() {
  digitalWrite(LED1,LOW);
 handleWebsite();
  handleXML();
void handleblinkled() {
if(millis()>wait001){
    digitalWrite(LED1,!digitalRead(LED1));
    wait001=millis()+blinkSpeed;
  buildWebsite();
  dht.setup(DHTPIN);
  pinMode(ledPIN, OUTPUT); //Chan Led Dimmer
  pinMode(INPUT_PIN, INPUT);//Chan cam bien PIR
  oldInputState = !digitalRead(INPUT_PIN);
  pinMode(LED1,OUTPUT);
  WiFi.begin(ssid,password);
  while(WiFi.status()!=WL_CONNECTED)delay(500);
  WiFi.mode(WIFI_STA);
  Serial.println("\n\nBOOTING ESP8266 ...");
  Serial.println(ssid);
  Serial.print("Station IP address: ");
  server.on("/",handleWebsite);
  server.on("/xml",handleXML);
  server.on("/setBlinkspeed",handleBlinkspeed);
  server.on("/led1/1", handlebatled);
  server.on("/led1/0", handletatled);
  server.on("/led1/blink", handleblinkled);
  server.begin();
  server.handleClient();
  cambienpir();
  if(millis()>wait000){
    buildXML();
    wait000=millis()+1000UL;
  LED = constrain(sliderVal,0,1023);
        int diff_led = abs(LED-LED_A);
        if(diff_led > 0){
          led_delay = time_at_colour / abs(LED-LED_A);
        }else{
          led_delay = time_at_colour / 100;
    if(millis() - TIME_LED >= led_delay){
    TIME_LED = millis();
    LED_CHANGE();
  if ( (unsigned long) (millis() - time1) > 5000 ){
      cambienDHT22();
      cambienAnhSang();
  time1 = millis();
By karlTHO
#68193 Hello, i tried to extend the sketch to have two values display on the webserver but i don't arrive.
one or the other is display but not both of them.
here is you're code with few modif.
it will be really great if you have a solution.
i work on XML and javascript string
sorry for my english, i'm french.
const char* ssid="";
const char* password="";
  buildJavascript();
  webSite+="Runtime2 = <A id='runtime2'></A><BR>\n";
  webSite+="Runtime1 = <A id='runtime1'></A>\n";
  javaScript+="var xmlHttp=createXmlHttpObject();\n";
  javaScript+=" }\n";
  javaScript+="}\n";
  javaScript+=" if(xmlHttp.readyState==0 || xmlHttp.readyState==4){\n";
  javaScript+="   xmlHttp.onreadystatechange=handleServerResponse;\n"; // no brackets?????
  javaScript+=" }\n";
  javaScript+="}\n";
  javaScript+="function handleServerResponse(){\n";
  javaScript+=" if(xmlHttp.readyState==4 && xmlHttp.status==200){\n";
  javaScript+="   xmlResponse=xmlHttp.responseXML;\n";
  javaScript+="   xmldoc = xmlResponse.getElementsByTagName('response1');\n";
  javaScript+="   message = xmldoc[0].firstChild.nodeValue;\n";
  javaScript+="   document.getElementById('runtime1').innerHTML=message;\n";
  javaScript+="   xmldoc = xmlResponse.getElementsByTagName('response2');\n";
  javaScript+="   document.getElementById('runtime2').innerHTML=message;\n";
  javaScript+=" }\n";
  javaScript+="}\n";
void buildXML(){
//  XML+="<response2>";
//  XML+=millis();
//  XML+="</response2>";
  XML+="<response1>";
  XML+=millis2time();
  XML+="</response1>";
  String Time="";
  unsigned long ss;
  byte mm,hh;
  ss=millis()/1000;
  hh=ss/3600;
  mm=(ss-hh*3600)/60;
  if(hh<10)Time+="0";
  if(mm<10)Time+="0";
  if(ss<10)Time+="0";
  Time+=(String)ss;
  return Time;
  buildWebsite();
void handleXML(){
  buildXML();
  Serial.begin(9600);
  server.begin();
By karlTHO
#68195 Hello katz
  buildJavascript();
  javaScript+=" }\n";
  javaScript+="}\n";
  javaScript+=" }\n";
  javaScript+="}\n";
  javaScript+=" }\n";
  javaScript+="}\n";
void buildXML(){
//  XML+=millis();
  XML+="<response1>";
  XML+=millis2time();
  String Time="";
  unsigned long ss;
  byte mm,hh;
  ss=millis()/1000;
  hh=ss/3600;
  mm=(ss-hh*3600)/60;
  if(hh<10)Time+="0";
  if(mm<10)Time+="0";
  if(ss<10)Time+="0";
  Time+=(String)ss;
  return Time;
  buildWebsite();
void handleXML(){
  buildXML();
  Serial.begin(9600);
  server.begin();
By katz
#68252 @karlTHO,
When XML uses more than 1 variable you have to add a level in the XML-file. In your code I inserted lines 59 and 66. And then it works as expected.
Good luck, Peter.
const char* ssid="MyWiFi";
const char* password="123ac62thenet";
  buildJavascript();
  javaScript+=" }\n";
  javaScript+="}\n";
  javaScript+=" }\n";
  javaScript+="}\n";
  javaScript+=" }\n";
  javaScript+="}\n";
void buildXML(){
  XML="<?xml version='1.0' ?>";
  XML+="<xml>";
  XML+="<response2>";
  XML+=millis();
  XML+="<response1>";
  XML+=millis2time();
  XML+="</xml>";
  String Time="";
  unsigned long ss;
  byte mm,hh;
  ss=millis()/1000;
  hh=ss/3600;
  mm=(ss-hh*3600)/60;
  if(hh<10)Time+="0";
  if(mm<10)Time+="0";
  if(ss<10)Time+="0";
  Time+=(String)ss;
  return Time;
  buildWebsite();
void handleXML(){
  buildXML();
  Serial.begin(9600);
  server.begin();
