You can chat about native SDK questions and issues here.
By knoterich
#67663 hey everyone,
after three days of google fu, cursing the gods and way too much smoking I got to the end of my wisdom.
I set up the esp-open-sdk (https://github.com/pfalcon/esp-open-sdk) on an ubuntu OS, wired everything together on a breadboard (esp-100 an esp-07 without chip-antenna, ft232 breakout, powersupply).
It compiles without errors, flashes with verify but after resetting the ESP nothing happens. I can still read flash_id or chip_id with esptool but that is about it.
Makefile:
Code: Select allCC = xtensa-lx106-elf-gcc
CFLAGS = -I. -mlongcalls
LDLIBS = -nostdlib -Wl,--start-group -lmain -lnet80211 -lwpa -llwip -lpp -lphy -lc -Wl,--end-group -lgcc
LDFLAGS = -Teagle.app.v6.ld
blinky-0x00000.bin: blinky
   esptool.py elf2image $^
blinky: blinky.o
blinky.o: blinky.c
flash: blinky-0x00000.bin
   esptool.py --baud 19200 write_flash 0 blinky-0x00000.bin 0x10000 blinky-0x10000.bin
clean:
   rm -f blinky blinky.o blinky-0x00000.bin blinky-0x10000.bin
blinky.c:
Code: Select all/*
 * main.c
 *  Created on: 28/1/2016
 *      Author: usuario
#include "ets_sys.h"
#include "osapi.h"
#include "gpio.h"
#include "os_type.h"
#define user_procTaskPrio        0
#define user_procTaskQueueLen    1
os_event_t    user_procTaskQueue[user_procTaskQueueLen];
static void user_procTask(os_event_t *events);
static volatile os_timer_t some_timer;
void some_timerfunc(void *arg)
    //Do blinky stuff
    if (GPIO_REG_READ(GPIO_OUT_ADDRESS) & BIT2)
        //Set GPIO2 to LOW
        gpio_output_set(0, BIT2, BIT2, 0);
    else
        //Set GPIO2 to HIGH
        gpio_output_set(BIT2, 0, BIT2, 0);
//Do nothing function
static void ICACHE_FLASH_ATTR
    os_delay_us(10);
//Init function
user_init()
    // Initialize the GPIO subsystem.
    gpio_init();
    //Set GPIO2 to output mode
    PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO2_U, FUNC_GPIO2);
    //Set GPIO2 low
    //Disarm timer
    os_timer_disarm(&some_timer);
    //Setup timer
    os_timer_setfn(&some_timer, (os_timer_func_t *)some_timerfunc, NULL);
    //Arm the timer
    //&some_timer is the pointer
    //1000 is the fire time in ms
    //0 for once and 1 for repeating
    os_timer_arm(&some_timer, 1000, 1);
    //Start os task
    system_os_task(user_procTask, user_procTaskPrio,user_procTaskQueue, user_procTaskQueueLen);
The chain of commands is "make clean" -> "make" -> "make-flash"
I found an already compiled version of blinky (http://noosrequired.com/Javier_varez/te ... ree/master) and testet flashing to make sure there wasn't any hardware issue. And there wasn't.
The above code comes from Javier varez and the makefile is from the open-sdk Blinky example. Different Baudrates have also been tried.
This is the point I have to give up trying it on my own furthermore an am asking for help on this.
Greetings,
knoterich
