Using the new Arduino IDE for ESP8266 and found bugs, report them here
By Carlos Santos
#68258 I wouldn't say the problem is on my router side, since the same code works well on a nodemcu dev board that I have. When I say that LUA is working, I mean that I'm able to connect to the same AP and get an IP after uploading the lua script. I also have tried on different routers (all with at least 8 chars).
By philbowles
#71900 " I can't use it in STA or in SOFTAP modes" What does this mean? What happens when you try? What error mesages (if any) etc etc - be more specific.
Also , did you try powering off after programming then powering back up? Sometimes my Wemos D1s dont / wont / cant RST immediately after programming.
Reprogram. Power off. wait 5 . power on.
