By Barnabybear
#32384 Hi, found this sketch on Iot-playground. It needed a couple of tweeks but runs great.
GPIO 2 state can be changed from any browser on your local network. Also works with Andriod and iOS devices.
Change "your-ssid" & "your-password". Load up and follow instructions on serial terminal.
Code: Select all/*
 *  EasyloT sketch tweeked by Barnabybear - original @
 *  http://iot-playground.com/2-uncategorised/40-esp8266-wifi-relay-switch-arduino-ide
 *  This sketch demonstrates how to set up a simple HTTP-like server.
 *  The server will set a GPIO pin depending on the request
 *    http://server_ip/gpio/0 will set the GPIO2 low,
 *    http://server_ip/gpio/1 will set the GPIO2 high
 *  server_ip is the IP address of the ESP8266 module, will be
 *  printed to Serial when the module is connected.
const char* ssid = "your-ssid";
const char* password = "your-password";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
  delay(10);
  // prepare GPIO2
  pinMode(2, OUTPUT);
  digitalWrite(2, 0);
  // Connect to WiFi network
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  Serial.println("");
  // Start the server
  server.begin();
  Serial.println("Server started @ ");
  // Print the IP address & instructions
  Serial.println("To control GPIO, open your web browser.");
  Serial.println("To set GPIO 2 high, type:");
  Serial.print(WiFi.localIP());
  Serial.println("/gpio/1");
  Serial.println("To set GPIO 2 low, type:");
  Serial.println("/gpio/0");
  Serial.println("To toggle GPIO 2, type:");
  Serial.println("/gpio/2");
  if (!client) {
    delay(100);
    return;
  // Commented out by BB as gets stuck in while loop.
  // Wait until the client sends some data
  //Serial.println("new client");
  //while(!client.available()){
  //  delay(1);
  Serial.println(req);
  client.flush();
  // Match the request
  int val;
  if (req.indexOf("/gpio/0") != -1)
    val = 0;
  else if (req.indexOf("/gpio/1") != -1)
    val = 1;
  else if (req.indexOf("/gpio/2") != -1)
   val = (!digitalRead(2)); // <<<<< Edit: insert /gpio/3 lines after this line.
  else {
    Serial.println("invalid request");
    client.print("HTTP/1.1 404\r\n");
    client.stop();
    return;
  // Set GPIO2 according to the request
  digitalWrite(2, val);
  client.flush();
  // Prepare the response
  String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now ";
  s += (val)?"high":"low";
  s += "</html>\n";
  // Send the response to the client
  client.print(s);
  delay(1);
  Serial.println("Client disonnected");
  // The client will actually be disconnected
  // when the function returns and 'client' object is detroyed
A good starting place for many projects.
Have fun.
Edit: If you insert the following code,the suffix /gpio/3 will return the current state of the output without changing it.
Code: Select all  else if (req.indexOf("/gpio/3") != -1)
   val = (digitalRead(2));
By rastapapa
#46120 Hello, I have been experimenting with this code but really am not sure how to use it. What I want to do is have two ESP8266-12Es talk to each other over a local network. One will sense a momentary button and send the status to another ESP which will turn on a transistor that will enable an mp3 player. Can this be a springboard for such a project? Also if this is being connected to the network is ok if it has to be a dynamic IP address? Thanks!
By Mammuth
#48455 Just a small extension:
Code: Select all  // Prepare the response
  String ip = WiFi.localIP().toString();
  String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now";
  s += "<br><h2><a href=""http://" + ip + "/gpio/0"">Switch OFF</a></h2>";
  s += "<br><h2><a href=""http://" + ip + "/gpio/1"">Switch ON</a></h2>";
  s += "</html>\n";
Then you have a link on the page to switch ON/OFF the LED ;)
By johnnyfrx
#69324 Thank you all for posting this code and snippets. I've built a relay driven temperature controlled heatlamp for my wife's Gecko on an ESP w/Arduino which is also hosting a website displaying the temperature data and some counters. This code will be a nice addition to provide an 'override' of sorts to manually control the heatlamp if/when needed without having to unplug anything.
