By Amin_Abdiyan
#71630 Hardware
Hardware: ESP-12f
Core Version: 2.3.0
Description
ESP8266 access point disappears after a while. Can I check that access point exists in loop? I use WiFi.getMode() ,WiFi.softAPIP() but not changed after disappearing AP.
Settings in IDE
Module: Generic ESP8266 Module
Flash Size: 1MB
CPU Frequency: 80Mhz //I also checked 160Mhz
Flash Mode: qio //I also checked dio
Flash Frequency: 80Mhz
Upload Using: SERIAL
Reset Method: ck
I choose different IDE settings(Node mcu,Adafruit Huzzah ESP8266) but problem persist.
Sketch(summary)
#include <ESP8266WebServer.h>
#include <FS.h>
#include "EEPROM.h"
#include "_74HC595.h"
#include "MD5.h"
#include "RemoteReceiver2.h"
#include <ESP8266mDNS.h> //I don't use this library in AP mode
extern "C" {
#include "user_interface.h"
ESP8266WebServer* server;
IPAddress apIP(192, 168, 3, 1);
WiFi.mode(WIFI_AP);
WiFi.persistent(true);
WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
WiFi.softAP(SSIDName,WiFiAPPSK,6); // I checked WiFi.softAP(SSIDName,WiFiAPPSK) too.
server=new ESP8266WebServer(80);
server->on("/r", HTTP_POST, {
server->onNotFound( {
if (!handleFileRead(server->uri()))
server->send(404, "text/plain", "FileNotFound");
server->begin();
Udp.begin(2390);
server->handleClient();
packetSize = Udp.parsePacket();
if (packetSize)
packetBuffer[0] = 0; //buffer to hold incoming packet
packetBuffer[1] = 0;
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
Udp.write("h");
Debug Messages
I delete board esp8266 and reinstall it today after that when I enable debug on Serial WDT resets(I don't know why)
there is no poison after the block. Expected poison address: 0x3fff2ab4, actual data: 0xaf 0x0 0xa5 0xa5
block start: 3fff2a04
Panic C:\Users\amin_\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\umm_malloc\umm_malloc.c:853 check_poison_block
ctx: sys
sp: 3ffffd40 end: 3fffffb0 offset: 01b0
>>>stack>>>
3ffffef0: 5ffffe00 5ffffe00 3ffefb28 40100334
3fffff00: 4a00361f 00000ca0 3fff29f8 4010044f
3fffff10: 4f4cbf71 ffffffff 3fff0420 4010054f
3fffff20: ffffffff 3fff1a38 3fff1dfc 401008d9
3fffff30: ffffffff ffffffff 00007bc6 40106f8c
3fffff40: 40105246 00007bc4 ffffffff 402331e5
3fffff50: 401060b4 00000000 00007bc4 00000000
3fffff60: 40228d0c 3ffefae8 3ffefb10 60000600
3fffff70: 021040fa 3ffefb10 3ffefae8 40228d19
3fffff80: 40228d5e 3fffdab0 00000000 3fffdcb0
3fffff90: 3ffefb30 3fffdad0 3fff0500 40211253
3fffffa0: 40000f49 97b9bbff 3fffdab0 40000f49
<<<stack<<<
ets Jan 8 2013,rst cause:1, boot mode:(1,6)
ets Jan 8 2013,rst cause:4, boot mode:(1,6)
wdt reset
thanks in advance
sorry for my English
By philbowles
#71756
Amin_Abdiyan wrote:sorry for my English
There is no problem with your English.
The problem is...in the code you didn't post.
"Eyeballing" code is a poor substitute for finding bugs when compared with actually running a copy of it. Also - in my experience - it's often the bit that is "nothing to do with it" that is actually where the bug is...
Post all your code and I'll gladly have a look at it running on one of my own devices.
By rudy
#71761 It is good to remove as much out of the code, as you can as long as what you post compiles, can still run, and also has the same problem behaviour as the full code. If those conditions are not met then it often is just a waste of everyone's time.
By philbowles
#71766
rudy wrote:It is good to remove as much out of the code, as you can as long as what you post compiles, can still run, and also has the same problem behaviour as the full code. If those conditions are not met then it often is just a waste of everyone's time.
Yes, that's good too - a lot more work though!
