By Pablo2048
#71836 If you need websocket server in async mode, the simplest way is to use ESPAsyncWebServer which contain websocket plugin. Your'e not using async method in your code because of websocket.loop() in your loop() (async method are async so no more .loop() things...) I hope that your'e not a noob - async things are more complicated and require more knowledge than simlpe sync things from core...
By Josep112
#71910 I am testing ESP_AsyncFSBrowser that is in the example of ESPAsyncWebServer but without success because when restarto esp I can not but send data if not restart the websocket client from the other side
By Josep112
#71914 I connect in this code by a websocket client and it works perfectly, but when the Esp is restarted it stops receiving data, it only comes back if I restart the websocket client, for tests I use the ws of google chome
#include <ESP8266mDNS.h>
#include <ArduinoOTA.h>
#include <FS.h>
#include <Hash.h>
#include <ESPAsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include <SPIFFSEditor.h>
// SKETCH BEGIN
AsyncWebServer server(80);
AsyncWebSocket ws("/ws");
AsyncEventSource events("/events");
void onWsEvent(AsyncWebSocket * server, AsyncWebSocketClient * client, AwsEventType type, void * arg, uint8_t *data, size_t len){
if(type == WS_EVT_CONNECT){
Serial.printf("ws[%s][%u] connect\n", server->url(), client->id());
client->printf("Hello Client %u :)", client->id());
client->ping();
} else if(type == WS_EVT_DISCONNECT){
Serial.printf("ws[%s][%u] disconnect: %u\n", server->url(), client->id());
} else if(type == WS_EVT_ERROR){
Serial.printf("ws[%s][%u] error(%u): %s\n", server->url(), client->id(), *((uint16_t*)arg), (char*)data);
} else if(type == WS_EVT_PONG){
Serial.printf("ws[%s][%u] pong[%u]: %s\n", server->url(), client->id(), len, (len)?(char*)data:"");
} else if(type == WS_EVT_DATA){
AwsFrameInfo * info = (AwsFrameInfo*)arg;
String msg = "";
if(info->final && info->index == 0 && info->len == len){
//the whole message is in a single frame and we got all of it's data
Serial.printf("ws[%s][%u] %s-message[%llu]: ", server->url(), client->id(), (info->opcode == WS_TEXT)?"text":"binary", info->len);
if(info->opcode == WS_TEXT){
for(size_t i=0; i < info->len; i++) {
msg += (char) data[i];
} else {
char buff[3];
sprintf(buff, "%02x ", (uint8_t) data[i]);
msg += buff ;
Serial.printf("%s\n",msg.c_str());
client->text("I got your text message");
else
client->binary("I got your binary message");
} else {
//message is comprised of multiple frames or the frame is split into multiple packets
if(info->index == 0){
if(info->num == 0)
Serial.printf("ws[%s][%u] %s-message start\n", server->url(), client->id(), (info->message_opcode == WS_TEXT)?"text":"binary");
Serial.printf("ws[%s][%u] frame[%u] start[%llu]\n", server->url(), client->id(), info->num, info->len);
Serial.printf("ws[%s][%u] frame[%u] %s[%llu - %llu]: ", server->url(), client->id(), info->num, (info->message_opcode == WS_TEXT)?"text":"binary", info->index, info->index + len);
} else {
char buff[3];
msg += buff ;
if((info->index + len) == info->len){
Serial.printf("ws[%s][%u] frame[%u] end[%llu]\n", server->url(), client->id(), info->num, info->len);
if(info->final){
Serial.printf("ws[%s][%u] %s-message end\n", server->url(), client->id(), (info->message_opcode == WS_TEXT)?"text":"binary");
if(info->message_opcode == WS_TEXT)
else
const char* ssid = "CASA_NET";
const char* password = "jose18011619";
const char * hostName = "esp-async";
const char* http_username = "admin";
const char* http_password = "admin";
void setup(){
Serial.setDebugOutput(true);
WiFi.hostname(hostName);
WiFi.mode(WIFI_AP_STA);
WiFi.softAP(hostName);
WiFi.begin(ssid, password);
if (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.printf("STA: Failed!\n");
WiFi.disconnect(false);
delay(1000);
//Send OTA events to the browser
ArduinoOTA.onStart([]() { events.send("Update Start", "ota"); });
ArduinoOTA.onEnd([]() { events.send("Update End", "ota"); });
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
char p[32];
sprintf(p, "Progress: %u%%\n", (progress/(total/100)));
events.send(p, "ota");
ArduinoOTA.onError([](ota_error_t error) {
if(error == OTA_AUTH_ERROR) events.send("Auth Failed", "ota");
else if(error == OTA_BEGIN_ERROR) events.send("Begin Failed", "ota");
else if(error == OTA_CONNECT_ERROR) events.send("Connect Failed", "ota");
else if(error == OTA_RECEIVE_ERROR) events.send("Recieve Failed", "ota");
else if(error == OTA_END_ERROR) events.send("End Failed", "ota");
ArduinoOTA.setHostname(hostName);
ArduinoOTA.begin();
MDNS.addService("http","tcp",80);
SPIFFS.begin();
ws.onEvent(onWsEvent);
server.addHandler(&ws);
events.onConnect([](AsyncEventSourceClient *client){
client->send("hello!",NULL,millis(),1000);
server.addHandler(&events);
server.addHandler(new SPIFFSEditor(http_username,http_password));
server.on("/heap", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(200, "text/plain", String(ESP.getFreeHeap()));
server.serveStatic("/", SPIFFS, "/").setDefaultFile("index.htm");
server.onNotFound([](AsyncWebServerRequest *request){
Serial.printf("NOT_FOUND: ");
if(request->method() == HTTP_GET)
Serial.printf("GET");
else if(request->method() == HTTP_POST)
Serial.printf("POST");
else if(request->method() == HTTP_DELETE)
Serial.printf("DELETE");
else if(request->method() == HTTP_PUT)
Serial.printf("PUT");
else if(request->method() == HTTP_PATCH)
Serial.printf("PATCH");
else if(request->method() == HTTP_HEAD)
Serial.printf("HEAD");
else if(request->method() == HTTP_OPTIONS)
Serial.printf("OPTIONS");
else
Serial.printf("UNKNOWN");
Serial.printf(" http://%s%s\n", request->host().c_str(), request->url().c_str());
if(request->contentLength()){
Serial.printf("_CONTENT_TYPE: %s\n", request->contentType().c_str());
Serial.printf("_CONTENT_LENGTH: %u\n", request->contentLength());
int headers = request->headers();
int i;
for(i=0;i<headers;i++){
AsyncWebHeader* h = request->getHeader(i);
Serial.printf("_HEADER[%s]: %s\n", h->name().c_str(), h->value().c_str());
int params = request->params();
for(i=0;i<params;i++){
AsyncWebParameter* p = request->getParam(i);
if(p->isFile()){
Serial.printf("_FILE[%s]: %s, size: %u\n", p->name().c_str(), p->value().c_str(), p->size());
} else if(p->isPost()){
Serial.printf("_POST[%s]: %s\n", p->name().c_str(), p->value().c_str());
} else {
Serial.printf("_GET[%s]: %s\n", p->name().c_str(), p->value().c_str());
request->send(404);
server.onFileUpload([](AsyncWebServerRequest *request, const String& filename, size_t index, uint8_t *data, size_t len, bool final){
if(!index)
Serial.printf("UploadStart: %s\n", filename.c_str());
Serial.printf("%s", (const char*)data);
if(final)
Serial.printf("UploadEnd: %s (%u)\n", filename.c_str(), index+len);
server.onRequestBody([](AsyncWebServerRequest *request, uint8_t *data, size_t len, size_t index, size_t total){
if(!index)
Serial.printf("BodyStart: %u\n", total);
if(index + len == total)
Serial.printf("BodyEnd: %u\n", total);
server.begin();
void loop(){
ArduinoOTA.handle();
