By hortplus
#73306 i'm trying to send data to a mysql database. I have written the php script to store data. Works well. However sending from my wemos r1 d1 doesn't seem to work. I have put:
printWifiStatus();
// Connect to the server (your computer or web page)
if (client.connect(server, 80)) {
Serial.println("--> connection ok\n");
Serial.println("1000");
client.print("GET /write_met.php?"); // This is the get request
client.print("temperature="); // This is the temperature
client.print("100"); // And this is what we did in the testing section above. We are making a GET request just like we would from our browser but now with live data from the sensor
client.print("&leafwetness=");
client.println(" HTTP/1.1"); // Part of the GET request
client.print( "Host: " );
client.println(server);
client.println("Connection: close"); // Part of the GET request telling the server that we are over transmitting the message
client.println(); // Empty line
client.stop(); // Closing connection to server
Serial.println("--> finished transmission\n");
Anything obvious with what i'm doing wrong?
By hortplus
#73350 I ended up with this:
const char* ssid = "**";
const char* password = "**";
const char* host = "www.yourhost.com";
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.println("");
int value = 0;
delay(5000);
++value;
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
return;
// We now create a URI for the request
String url = "/write_met.php?logger=200&temperature=10&leafwetness=10";
Serial.print("Requesting URL: ");
Serial.println(url);
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
delay(60000);
Serial.println("Respond:");
while(client.available()){
Serial.print(line);
Others might find it useful
