By Truglodite
#82466 First I want to use my first post to thank Barnabybear for posting his idea! :D
I've been using a similar circuit on a few li-ion powered esp8266 pir sensors for a few years, and they are working great... about 1yr life with a Vbatt divider too!
That said, I recently built a micro amp meter project and started playing around with the AM312 pir sensors. The AM312 only draws 15uA both active and inactive, compared to the usual hc-sr501 which burns 35uA inactive, and 77uA active. I'm sure I'm not the first to try to retrofit an am312 to this circuit and find out it doesn't work. I looked with my oscope and sure enough the am312 output is just too weak to drive the resistors & diode.
This can be fixed with a pfet or non-inverting buffer. I should've probably gone the pfet route to save myself from challenging solder work, but I fell in love with the small ground current of newer CMOS buffers. So I ordered some NL17SG17 schmitt buffers and dead bug soldered them to the AM312, after cutting the output trace (between the output resistor and output pin). I cut the trace so I could still use the original pins for wiring to 3v3 and the diode circuit, but there's other ways to do it I suppose. After testing, yep... 15uA idle current and the signal is a solid 0-3v3 output @5mA... now the AM312 drives the wake circuit with ease!
Here is an image I made of the wiring/soldering:
Next I'll have to read up on the esp8266 a0 impedance, and see if I can tweak the Vbatt divider for minimum current... regardless, I recommend anyone who is after more battery life from an ESP/PIR node, give this AM312 mod a shot.
Cheers,
Kev
By AndroMan
#86546 Hello.
I tested the CH_PD with GPIO option for a battery button.
If i set the GPIO to LOW the ESP-07 switched off, but not 100%
The on board LED light a little bit, and the current is like use of ESP.deepsleep(0)
If i made this by myself, pulling out the CH_PD cable, current is very low and LED off.
ESP.deepsleep = 0,015mA
CH_PD off with GPIO = 0,020mA
CH_PD off by pull the wire = very very low 0,002mA ? I forgot the value.
Then i see the problem is if CH_PD will set to GND, like with an resistor.
So i think if i set an GPIO pin to LOW it will set to GND ?
At the first pages here i see an example with to AA batteries, an diode and resistor.
But will it really work ? Anyone test the current to ESP.deepsleep?
Or is there a different between ESP-01 and ESP-07 ?
At the moment i use ESP.deepsleep(0) and connect an button to the RESET pin.
But two AA batteries (akkus) will be to fast empty
