By UsernamePersonThingy
#75159 Hi, I have been using this for a while and i works perfectly. I can tell siri to change the lights without having to reach for a remote and point it a t the controller. :D . I have the NodeMCU powered by my iMac as I don't have a voltage regulator yet. I am just curious about the TIP122 as they get quite hot when in use. It depends which colour I have the lights on. I have a simple diagram of my connections below, I'll also include my code. I would appreciate it if anyone could tell me if this is normal or if I have a problem. Thanks. :)
Code: Select all//NodeMCU RGB-Controller for Homebridge & HomeKit (Siri)
#define redPin 13 //D7 - Red channel
#define grnPin 12 //D6 - Green channel
#define bluPin 14 //D5 - Blue channel
#define max(a,b) ((a)>(b)?(a):(b))
WiFiServer server(80); //Set server port
String readString;           //String to hold incoming request
String hexString = "000000"; //Define inititial color here (hex value), 080100 would be a calm warmtone i.e.
int state;
int r;
int g;
int b;
float R;
float G;
float B;
int x;
int V;
///// WiFi SETTINGS - Replace with your values /////////////////
const char* ssid = "xxx";
const char* password = "xxx";
IPAddress ip(x,x,x,x);      // set a fixed IP for the NodeMCU
IPAddress gateway(x,x,x,x);  // Your router IP
IPAddress subnet(255,255,255,0); // Subnet mask
void WiFiStart() {
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  WiFi.config(ip, gateway, subnet); //Set a fixed IP. You can comment this out and set it in your router instead.
    delay(100);
    Serial.print("_");
  Serial.println("Done");
  Serial.print("IP address: ");
  Serial.println("");
  server.begin();
void allOff() {
  state = 0;
  analogWrite(redPin, 0);
  analogWrite(grnPin, 0);
  analogWrite(bluPin, 0);
//Write requested hex-color to the pins (10bit pwm)
void setHex() {
  state = 1;
  long number = (long) strtol( &hexString[0], NULL, 16);
  r = number >> 16;
  g = number >> 8 & 0xFF;
  b = number & 0xFF;
  r = map(r, 0, 255, 0, 1023);  //added for 10bit pwm
  g = map(g, 0, 255, 0, 1023);  //added for 10bit pwm
  b = map(b, 0, 255, 0, 1023);  //added for 10bit pwm
  analogWrite(redPin, (r));
  analogWrite(grnPin, (g));
  analogWrite(bluPin, (b));
//Compute current brightness value
void getV() {
  R = roundf(r/10.23);  //for 10bit pwm, was (r/2.55);
  G = roundf(g/10.23);  //for 10bit pwm, was (g/2.55);
  B = roundf(b/10.23);  //for 10bit pwm, was (b/2.55);
  x = max(R,G);
  V = max(x, B);
//For serial debugging only
void showValues() {
  Serial.print("Status on/off: ");
  Serial.println(state);
  Serial.print("RGB color: ");
  Serial.print(r);
  Serial.print(".");
  Serial.print(g);
  Serial.print(".");
  Serial.println(b);
  Serial.print("Hex color: ");
  Serial.println(hexString);
  getV();
  Serial.print("Brightness: ");
  Serial.println(V);
  Serial.println("");
void setup(){
  Serial.begin(9600);
  delay(1);
  pinMode(redPin, OUTPUT);  //declaration added
  pinMode(grnPin, OUTPUT);  //declaration added
  pinMode(bluPin, OUTPUT);  //declaration added
  setHex(); //Set initial color after booting. Value defined above
  WiFi.mode(WIFI_STA);
  WiFiStart();
  //showValues(); //Uncomment for serial output
  //Reconnect on lost WiFi connection (superfluous - will reconnect anyway)
  /*if (WiFi.status() != WL_CONNECTED) {
    WiFiStart();
  if (!client) {
    return;
  while(client.connected() && !client.available()) {
    delay(1);
  //Respond on certain Homebridge HTTP requests
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (readString.length() < 100) {
          readString += c;
        if (c == '\n') {
          //Serial.print("Request: "); //Uncomment for serial output
          //Serial.println(readString); //Uncomment for serial output
          //Send reponse
          client.println("HTTP/1.1 200 OK");
          client.println("Content-Type: text/html");
          client.println();
          //On
          if(readString.indexOf("on") >0) {
            setHex();
            //showValues();
          //Off
          if(readString.indexOf("off") >0) {
            allOff();
            //showValues();
          //Set color
          if(readString.indexOf("set") >0) {
            hexString = "";
            hexString = (readString.substring(9,15));
            setHex();
            //showValues();
          //Status on/off
          if(readString.indexOf("status") >0) {
          client.println(state);
          //Status color (hex)
          if(readString.indexOf("color") >0) {
          client.println(hexString);
          //Status brightness (%)
          if(readString.indexOf("bright") >0) {
          getV();
          client.println(V);
          delay(1);
          client.stop();
          readString="";
#75203 I think that my power supply has enough amperage as it provides 2 amps and worked with without getting warm with the ir controller that originally came with my strip. The transistors get more hot depending on what colour they are on. For example if they are on red the red transistor would get hot.
