By whats_up_skip
#13084 I am surprised that there are no simple temperature and humidity sensors based on the ESP8266 listed.
I have found similar designs, but they also involve an Arduino type device in the circuit.
Example: http://www.instructables.com/id/ESP8266 ... ty-logger/
I thought the ESP8266 along with only a DHT22 temperature and humidity sensor and a few passive components would have been all that is required, or am I missing something here?
By Jan Marius Evang
#13086
whats_up_skip wrote:I am surprised that there are no simple temperature and humidity sensors based on the ESP8266 listed.
I made a temperature logger with a DHT11 + ESP8266(-01) + USB 3.3v power. Very simple with the nodemcu firmware and some pieces of code I found on the net. https://thingspeak.com/channels/29692
DHT22 is more accurate than DHT11.
Marius
By Jan Marius Evang
#13087 I should add that i first made it with only wires between the pins, but then made a pcb. You can order here: (I get 1$ credit if you do)
http://dirtypcbs.com/view.php?share=520 ... 458ea8742e
I used one of these modules
http://www.ebay.com/itm/New-DHT11-Tempe ... 4855679549
And didn't need any pull-up resistors on the pcb.
Marius
