Page 5 of 9
Re: remote control with only esp8266
Posted:
Sun Nov 29, 2020 10:35 am
by quackmore
avoid flashing the old binaries
did yo erased the flash first?
Posted:
Sun Nov 29, 2020 11:00 am
by quackmore
another thought...
from the images you attached to the previous post
it looks like that once you flash the old binary
it takes control and you start talking with the node firmware not the esp boot
that could be the reason you couldn't successfully flash and run the build generated by nodemcu-build.com
Posted:
Sun Nov 29, 2020 3:53 pm
by maxniz
I did a test by flashing only the your first block in(0x00000 )...after that, I continue to receive data from the serial ... to stop it I must to reset and return to my ancient file
Posted:
Sun Nov 29, 2020 4:15 pm
by quackmore
I think it's a good sign,
the problem is into the flashing process you are using
and probably you are really flashing a binary now!
that first file is the SDK, it cannot run alone...
you have three chances:
1) use the same tool and try flashing the file (just that, no other one) you received from nodemcu-build.com (flash it at 0x00000)
2) use the same tool and try flashing the binaries I built but revert the order, start with file 0x10000.bin then file 0x00000.bin (don't forget to revert the addresses too)
3) change the flashing tool, have you tried the Espressif one or esptool.py ?
