By folny82
#20206 Hi
I tested your code ESP8266 Flash Tool but I was unable to update the code several times in succession after the first update in about half of the update, the update is interrupted do not know where anyone can be a problem ? I tested the code with the ESP-01 and ESP-03 module.
By taribo_m
#22491 Hi Max,
I can't run the PC application under WinXP SP3 (the error I got is: Wifi Flash Tool v1.1.exe is not a valid Win32 application). On a Win7 OS is runs OK. Maybe I need to install .NET Framework on WinXP (I will try this later).
Can you share the code for the PC application ?
EDIT: I have installed .NET Framework 4.0.3 and still can't run the application, under WinXP.
By maxtronik
#22683 Hi,
please download the Tool again. I now builded it with .net Framework 4.0.
Before that it was build with .net 4.5 :geek:
I do not have a XP computer here, so I'm not able to test it.
