By sh4d0w
#17828
juanpintom wrote:Am trying to make the first sketch for reading from IR but I've problems to add the library to the IDE, I added many libraries on Arduino IDE, but on the github I found some files (application.cpp, user_config.h, etc.. ) and structure that I don't know how to copy on ESP IDE. Any help on this? Sorry if it's a newbie question :S
Here is my sketch working wih Souliss and Arduino using IRlib (Irremote) library.
http://pastebin.com/2sEJ4JrV
Regards!
I haven't used the Arduino IDE for the ESP8266 so can't help you there. Both application.cpp and user_config.h are esp8266 specific. application.cpp contains the main execution code and user_config.h are for user defined configuration variables. Currently application.cpp is just a demonstration on how to run the library on the esp8266 it is not necessary to use the library. I think you might have to do some work to the script I don't think you can just throw it in as is. I could be wrong though.
By juanpintom
#17857 Sorry, I forget that this isn't the "Arduino IDE ESP" forum :S
I'll try to make an example to use on the IDE using application.cpp.
Really thanks! I'll take a look an let you know.
By juanpintom
#18008 Im trying to integrate SmingCore to the Arduino ESP IDE with no results, I tried to extract the Timer.h and associated files with no success. I keep trying but my knowledge its limited on this, any help is appreciated.
Regards
By anakod
#18011 sh4d0w, this is great work! Thank you very much.
Would you like to make a pull-request to include this library and related example in the main Sming distribution (preserving your copyrights, of course)?
