By omersiar
#22416 Very well done sir ! Thank you. I ve been trying "transparent bridges", this is the most amazing one. It works, well coded, rock solid, GPL licensed :), what can i expect more? I am now testing it with my quadcopter (Ardupilot based APM) as telemetry module, your firmware can achieve higher data rates, and there are no dropped packets at all. Thank you again, have a nice day.
By tytower
#22874 "transparent bridges"..? so why don't you correct the heading of the thread if that's what this is .
Its difficult enough to understand all the names for things people are working on without the spelling being wrong too. No offence meant. It is important, at times, to get the spelling right.
16 bits PWM mode, running at 330 Hz, suitable for driving lighting
I understood that the pins were 10 bit PWM . Are you able to increase them in some way add to the register size?
Can this be used in any way to boot the ESP in SDIO mode from an SD card?
