Re: Demo: I2S sound output and MP3 decoding in an ESP8266
Posted: Sun Jun 07, 2015 8:20 am
Sprite_tm wrote:alonewolfx2 wrote:finally great work. can we use this example on 512kb flash? if we can use what is firmware addresses?
I think so. The default compile may seem to be for an 1024K flash device, but that's only because the standard 512K ld file seems to want to split the rom in two 256K segments, and that won't fit. You can try just compiling it as-is and flashing it to the addresses indicated in the README.md, I think that should work. I can't check, unfortunately, I don't have any 512K modules at hand; if you do try it, I'd love to hear if it works.
i tried and its not booting.and i tried to change ld file with original rtos sdk ld file and i am getting ".irom0.text' will not fit in region `irom0_0_seg'
