By Marc_H
#19821 Hi guys,
at first sorry for bad english! I hope you can help me ;)
I write a sketch to control my RGB-LED-Stripes via the ESP8266 and 3 N-Channel MOSFETs, it works fine but sometimes without any Error via Serial or hang up all ticker's the server don't answer anymore, i use a LED on port 14 turn on and of every second by a ticker and it works the hole time without a problem!?
My Code:
Code: Select all/*
 *  This sketch demonstrates how to set up a simple HTTP-like server.
 *  The server will set a GPIO pin depending on the request
 *    http://server_ip/gpio/0 will set the GPIO2 low,
 *    http://server_ip/gpio/1 will set the GPIO2 high
 *  server_ip is the IP address of the ESP8266 module, will be
 *  printed to Serial when the module is connected.
#include <Ticker.h>
Ticker fader;
Ticker aLife;
const char* ssid = "SSID";
const char* password = "PW";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
unsigned int rColor;
unsigned int gColor;
unsigned int bColor;
boolean fadeEnabled = false;
boolean fadeUp = true;
unsigned int fadeState = 0;
double fadeSpeed = 5;
void aLifeLed()
  if (digitalRead(14) == true)
    digitalWrite(14, LOW);
    digitalWrite(14, HIGH);
void fadeStart()
  fadeState = 0;
  fadeEnabled = true;
  fader.attach(fadeSpeed/1000, fadeChange);
void fadeStop()
  fader.detach();
void fadeChange()
  if (fadeState <= 0)
    fadeUp = true;
  else if (fadeState >= 1023)
    fadeUp = false;
  if (fadeUp == true)
    fadeState++;
    fadeState--;
  analogWrite(15,fadeState);
  analogWrite(13,fadeState);
  analogWrite(12,fadeState);
  delay(10);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(15, OUTPUT);
  pinMode(14, OUTPUT);
  aLife.attach(1, aLifeLed);
  ESP.wdtEnable(WDTO_0MS); // Allready working?
  // Connect to AcessPoint
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  Serial.println("Verbinde mit WLAN");
    Serial.print(".");
  Serial.println("");
  Serial.println("");
  Serial.print("WiFi \"");
  Serial.print(ssid);
  Serial.println("\" verbunden");
  // Print the IP address
  Serial.print("Eigene IP:");
  // Start the server
  server.begin();
  Serial.println("Server wurde gestartet");
  if (!client) {
    return;
  while(!client.available()){
    delay(10);
  //Serial.println(req);
  client.flush();
  // Match the request
  if (req.indexOf("/rgb?") != -1)
    String r = "";
    String g = "";
    String b = "";
    // read colors from request
    int rStart = req.indexOf("r=") + 2;
    int gStart = req.indexOf("g=") + 2;
    int bStart = req.indexOf("b=") + 2;
    int rEnd = req.indexOf("&",rStart);
    int gEnd = req.indexOf("&",gStart);
    int bEnd = req.indexOf(" ",rStart);
    r = req.substring(rStart,rEnd);
    g = req.substring(gStart,gEnd);
    b = req.substring(bStart,bEnd);
    // Set LED Color
    rColor = r.toInt();
    gColor = g.toInt();
    bColor = b.toInt();
    fadeStop();
    analogWrite(15,rColor);
    analogWrite(13,gColor);
    analogWrite(12,bColor);
  else if (req.indexOf("/rgb") != -1)
    // Show Site only
  else if (req.indexOf("/fade?I") != -1)
    fadeStart();
  else if (req.indexOf("/fade?O") != -1)
    fadeStop();
  else {
    Serial.println("invalid request");
    client.flush(); // Need to flush?
    return;
  client.flush(); // Need to flush?;
  // Prepare the response
  String s = "<!DOCTYPE HTML PUBLIC '-//W3C//DTD HTML 4.01 Transitional//EN'><html><head><meta http-equiv='Cache-Control' content='no-store' /><meta name='viewport' content='width=100'/><link rel='icon' type='image/png' href='data:image/gif;base64,R0lGODlhDwAPAKECAAAAzMzM/////wAAACwAAAAADwAPAAACIISPeQHsrZ5ModrLlN48CXF8m2iQ3YmmKqVlRtW4MLwWACH+H09wdGltaXplZCBieSBVbGVhZCBTbWFydFNhdmVyIQAAOw==";
  s += "' /><title>RGB ColorControl V0.1(Alpha)</title>";
  s += "<script>function changeBackColor () { var red = document.getElementById('r').value; var green = document.getElementById('g').value; var blue = document.getElementById('b').value; red = Math.round(red / 4); green = Math.round(green / 4); blue = Math.round(blue / 4);";
  s += " document.body.style.backgroundColor = 'rgb(' + red + ',' + green + ',' + blue + ')';} ";
  s += "</script></head><body onload='javascript:changeBackColor()'";
  s += "><form action='rgb' method='get'><center>";
  s += "<input type='range' id='r' name='r' value='";
  s += rColor;
  s += "' oninput='javascript:changeBackColor()' onchange='javascript:changeBackColor()' min='0' max='1023'/><br>";
  s += "<input type='range' id='g' name='g' value='";
  s += gColor;
  s += "<input type='range' id='b' name='b' value='";
  s += bColor;
  s += "' oninput='javascript:changeBackColor()' onchange='javascript:changeBackColor()' min='0' max='1023'/><br><br><button type='submit'>Erleuchten</button></center></form></body></html>";
  client.print(s);
  delay(1);
Serial Output:
Code: Select allÈHÌc/hÌøD�•„….ørlVerbinde mit WLAN
WiFi "ChaosWG" verbunden
Eigene IP:192.168.178.37
I use this SDK-Board:
