By Douglas C. Santos
#24948 I'm very excited to finally be able to control my wemo switches with the esp8266. Below is the code I used for. It is just a simple example, need to add a button and filter the response from the switch to check the wemo status. ar
Hoping to hear some feedback and improvements from you guys.
Code: Select all--------------------------------------------------------------------
 *  This sketch sends data via HTTP POST requests to a wemo device.
const char* ssid     = "Your_Wifi";
const char* password = "Your_password";
const char* host = "192.168.0.179";
const int port = 49153;
int wemo_status = 0;
String wemo_on="<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body><u:SetBinaryState xmlns:u=\"urn:Belkin:service:basicevent:1\"><BinaryState>1</BinaryState></u:SetBinaryState></s:Body></s:Envelope>";
String wemo_off="<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body><u:SetBinaryState xmlns:u=\"urn:Belkin:service:basicevent:1\"><BinaryState>0</BinaryState></u:SetBinaryState></s:Body></s:Envelope>";
  delay(10);
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  if (wemo_status == 0) {
    wemo_status = 1;
    Serial.println("Turning WeMo On...");
  else {
    wemo_status = 0;
    Serial.println("Turning WeMo Off...");
  wemo_control(wemo_status);
  delay(5000);
void wemo_control(int cmd) {
  Serial.println(host);
  WiFiClient client;
  if (!client.connect(host, port)) {
    Serial.println("Connection failed");
    return;
  client.println("POST /upnp/control/basicevent1 HTTP/1.1");
  client.println("Host: " + String(host) + ":" + String(port));
  client.println("User-Agent: ESP8266/1.0");
  client.println("Connection: close");
  client.println("Content-type: text/xml; charset=\"utf-8\"");
  client.print("Content-Length: ");
  if (cmd == 1) {
    client.println(wemo_on.length()); // both wemo_on and wemo_off are the same length, just in case it changes in the future
  else {
     client.println(wemo_off.length());
  client.println("SOAPACTION: \"urn:Belkin:service:basicevent:1#SetBinaryState\"");
  client.println();
  if (cmd == 1) {
      client.println(wemo_on);
  else {
      client.println(wemo_off);
  delay(10);
  while(client.available()){
    Serial.print(line);
  Serial.println("Closing connection");
I used the following sites to help me reach the outcome.
WeMo Hacking - http://mattenoble.com/2013/08/07/wemo-hacking/
Working HTTP POST example - http://forum.arduino.cc/index.php?topic=155218.0
an-Piet Mens :: Sonos pause switch - http://jpmens.net/2010/03/16/sonos-pause-switch/
By tytower
#24971 Wemo is looking promising as home security devices so this should help the experimenters . Its all a bit pricey yet for me at $80 for a PIR and $130 for a camera plus you have to have a home network running too. Cant do that in my applications yet.
