I spend the last days figuring out the code for the bootloader and the
memory mapping.
I got the bootloader running and thought I was ready for the next step but
had a problem with the rboot-sampleproject.
I'm used the build my roms from a Windows environment with the use of mingw and Eclipse.
No problems so far with the projects I tried.
The rboot-sampleproject gives me the following error.
23:03:30 **** Build of configuration Default for project rboot-sampleproject ****
mingw32-make.exe -f C:/Espressif/examples/rboot-sampleproject/Makefile all
LD rom0.elf
build/rboot.o: In function `call_user_start':
C:\Espressif\examples\rboot-sampleproject/rboot.c:352: multiple definition of `call_user_start'
C:/Espressif/examples/rboot-sampleproject/Makefile:46: recipe for target 'build/rom0.elf' failed
C:/esp_iot_sdk_v1.3.0/lib\libmain.a(vector.o):(.UserEnter.text+0x8): first defined here
collect2.exe: error: ld returned 1 exit status
mingw32-make.exe: *** [build/rom0.elf] Error 1
23:03:31 Build Finished (took 1s.561ms)
As far as I understand this should be covered by -u call_user_start but it won't build.
( OS related ??? )
It would be nice if anyone could give me a hint.
Thanks, Datasung.
rab wrote:It looks like you've copied rBoot.c into the sample project by mistake, that shouldn't be the. Only copy in rBoot.h rboot-ota.c and rboot-ota.h
Thanks for the quick reply, not a completely wasted night after all.
I have a working example now and can continue.
My EPS module is to be build in to an Ikea lamp and I estimate that there will be a lot
of modifications.
So OTA firmware updates are essential for a starters.
I really have a lot to learn but I will get there.
Nice that you know your stuff so well .
greetings Datasung.
