By reaper7
#9832
lethe wrote:...
The LDO reaper7 suggested is probably the best & cheapest solution, but you should test how the LDO behaves if the input voltage drops below 3.4V.
3152mV and still works :D
probably a deepsleep current consumption bug in version 095
and I can see battery consumption in a shorter period of time..
next day...
2936mV and all systems still works :D
end ;)
2768mV
By ChrixXenon
#10150
miker wrote:I'm using aTPS61200DRCT to boost and regulate the power from a lipo with good luck so far. Attached is the schematic.
http://www.digikey.ca/product-detail/en/TPS61200DRCT/296-21663-1-ND/1534252
Bymiker, as far as I can tell this is a tiny surface mount device. How do you manage the physical aspects of using it?
By ChrixXenon
#10151
lethe wrote:
ChrixXenon wrote:Is there a clear winner product for this scenario?
I guess a clear winner would be something like the LTC3113. This is a combined buck-boost regulator, which can provide a stable 3.3V output with an input voltage from 1.8V-5.5V with a quiescence current of about 50uA.
But it's quite expensive and even the TSSOP package has to be reflowed, so it's impractical for most hobbyists.
But reaper's LDO is also in a tiny package as far as I can see from the datasheet. How does anyone without industrial micro-manipulation machinery use these things?
By GeoNomad
#10152
ChrixXenon wrote:I guess a clear winner would be something like the LTC3113. This is a combined buck-boost regulator, which can provide a stable 3.3V output with an input voltage from 1.8V-5.5V with a quiescence current of about 50uA.
FYI, I tried the MAX1724 which is a similar buck-boost.
input: 0.8-5.5V
Output: 3.3V (adjustable)
quiescent: 1.5 uA
Worked great with small LiPos.
