I’d like to build a thermostat with esp8266 and interface it to Alexa via Sinricpro. I must say that I am not very experienced and practical with the Sinricpro code; for the moment I only took the sample program from Github library "esp8266-esp32-sdk-master" called Thermostat.ino.
I have entered all the data for the Wi-Fi and Sinricpro connection, but at the moment it connects to the Internet (I have the serial feedback) but not to Sinricpro and also from its site is offline.
Do you have any advice?
Thank you
P.S. I enclose the code for practicality
* Example for how to use Lock device as garage door opener
* If you encounter any issues:
* - check the readme.md at https://github.com/sinricpro/esp8266-esp32-sdk/blob/master/README.md
* - ensure all dependent libraries are installed
* - see https://github.com/sinricpro/esp8266-esp32-sdk/blob/master/README.md#arduinoide
* - see https://github.com/sinricpro/esp8266-esp32-sdk/blob/master/README.md#dependencies
* - open serial monitor and check whats happening
* - check full user documentation at https://sinricpro.github.io/esp8266-esp32-sdk
* - visit https://github.com/sinricpro/esp8266-esp32-sdk/issues and check for existing issues or open a new one
// Uncomment the following line to enable serial debug output
//#define ENABLE_DEBUG
#ifdef ENABLE_DEBUG
#define DEBUG_ESP_PORT Serial
#define NODEBUG_WEBSOCKETS
#define NDEBUG
#endif
#include <Arduino.h>
#ifdef ESP8266
#endif
#ifdef ESP32
#include <WiFi.h>
#endif
#include "SinricPro.h"
#include "SinricProThermostat.h"
#define WIFI_SSID "YOUR_WIFI_SSID"
#define WIFI_PASS "YOUR_WIFI_PASSWORD"
#define APP_KEY "YOUR_APP_KEY_HERE" // Should look like "de0bxxxx-1x3x-4x3x-ax2x-5dabxxxxxxxx"
#define APP_SECRET "YOUR_APP_SECRET_HERE" // Should look like "5f36xxxx-x3x7-4x3x-xexe-e86724a9xxxx-4c4axxxx-3x3x-x5xe-x9x3-333d65xxxxxx"
#define THERMOSTAT_ID "YOUR_DEVICE_ID_HERE" // Should look like "5dc1564130xxxxxxxxxxxxxx"
#define BAUD_RATE 115200 // Change baudrate to your need
float globalTemperature;
bool globalPowerState;
bool onPowerState(const String &deviceId, bool &state) {
Serial.printf("Thermostat %s turned %s\r\n", deviceId.c_str(), state?"on":"off");
globalPowerState = state;
return true; // request handled properly
bool onTargetTemperature(const String &deviceId, float &temperature) {
Serial.printf("Thermostat %s set temperature to %f\r\n", deviceId.c_str(), temperature);
globalTemperature = temperature;
return true;
bool onAdjustTargetTemperature(const String & deviceId, float &temperatureDelta) {
globalTemperature += temperatureDelta; // calculate absolut temperature
Serial.printf("Thermostat %s changed temperature about %f to %f", deviceId.c_str(), temperatureDelta, globalTemperature);
temperatureDelta = globalTemperature; // return absolut temperature
return true;
bool onThermostatMode(const String &deviceId, String &mode) {
Serial.printf("Thermostat %s set to mode %s\r\n", deviceId.c_str(), mode.c_str());
return true;
void setupWiFi() {
Serial.printf("\r\n[Wifi]: Connecting");
WiFi.begin(WIFI_SSID, WIFI_PASS);
Serial.printf(".");
delay(250);
IPAddress localIP = WiFi.localIP();
Serial.printf("connected!\r\n[WiFi]: IP-Address is %d.%d.%d.%d\r\n", localIP[0], localIP[1], localIP[2], localIP[3]);
void setupSinricPro() {
SinricProThermostat &myThermostat = SinricPro[THERMOSTAT_ID];
myThermostat.onPowerState(onPowerState);
myThermostat.onTargetTemperature(onTargetTemperature);
myThermostat.onAdjustTargetTemperature(onAdjustTargetTemperature);
myThermostat.onThermostatMode(onThermostatMode);
// setup SinricPro
SinricPro.onConnected([](){ Serial.printf("Connected to SinricPro\r\n"); });
SinricPro.onDisconnected([](){ Serial.printf("Disconnected from SinricPro\r\n"); });
SinricPro.begin(APP_KEY, APP_SECRET);
Serial.begin(BAUD_RATE); Serial.printf("\r\n\r\n");
setupWiFi();
setupSinricPro();
SinricPro.handle();
