By Marshall
#13816 Hi,
I have setup an esp-07 to read from the ADC. It is working perfectly, but I do not see where in Tuan's user_main.c that I can put my code in a 'main' loop. Under function mqttConnectedCb(uint32_t *args) I have added a code snippet to read from the ADC and store it in a buffer to be written to topic '/mqtt/topic/adc':
Code: Select all
    MQTT_Publish(client, "/mqtt/topic/0", "hello0", 6, 0, 0);
    MQTT_Publish(client, "/mqtt/topic/1", "hello1", 6, 1, 0);
    MQTT_Publish(client, "/mqtt/topic/2", "hello2", 6, 2, 0);
    // Publish to ADC topic.
    uint8_t buffer[4];
    uint16 adc = system_adc_read();
    ets_sprintf( buffer, "%d", adc );
    MQTT_Publish(client, "/mqtt/topic/adc", buffer, 4, 1, 0);
The above gets run exactly one time AFAICT. I know the code is working OK, b/c I can publish (using mosquitto_pub) from my Mac terminal to the topics and it immediately pushes to the esp-07 subscriber. Also, I see the repeated keepAlive output.
I am a newbie at this and C is not a language I write code in for my day job. I'm just looking for that one comment that says:
Code: Select all// put main loop below here...
// end main loop.
In that main loop I would read from my ADC every n seconds and publish it to the mqtt broker.
Sorry if I'm not being clear. Sample code would be much appreciated!
Cheers,
Marshall
By m-cin
#13844 The code is event-driven. You could e.g. define a free-running timer and do your stuff when timer fires.
Code: Select all   static volatile os_timer_t some_timer;   //func declaration
   void ICACHE_FLASH_ATTR
   timer_callback_func(void)
//your code goes here...
//somewhere in user_main
   os_timer_disarm(&some_timer);
   os_timer_setfn(&some_timer, (os_timer_func_t *)timer_callback_func, 1);
   os_timer_arm(&some_timer, 50, 1);
Then everytime timer counts to zero, timer_callback_func is called. Parameters you may find in Espressif manual.
HTH
M.
By Marshall
#13902 Your advice helped me very much.
I added the following function near the top of user_main.c.
Code: Select all/* Read the ADC and publish to MQTT broker */
void ICACHE_FLASH_ATTR adcPublish( uint32_t *args ) {
    MQTT_Client* client = (MQTT_Client*)args;
    uint8_t buffer[4];
    INFO("MQTT: Read ADC value [%s]. Publishing now.\r\n", buffer);
At the bottom of the existing function declared as "void mqttConnectedCb(uint32_t *args)". I added:
Code: Select allos_timer_disarm(&adc_timer);
os_timer_setfn(&adc_timer, (os_timer_func_t *)adcPublish, client);
os_timer_arm(&adc_timer, 10000, 1);
Now every 10s the ADC value is being published to the broker (cloudmqtt.com in my case).
Thanks very much!
Marshall
