I just got my first modules before few days, so it is still early to say what is going to be, but if you like the idea
or already done something into same direction and it is not a secret, you are welcome to share
Explore... Chat... Share...
0ff wrote:Hey there,
I did actually connect a DHT-11 Temp sensor, as I had it in my parts box.
You can basically use the GPIOs for everything you can think of, so when you have setup the build evinronment, there's nothing stopping you from external peripherals at least.
