By CheapB
#3236
martinayotte wrote:
bkrajendra wrote:Only 'make htmlflash' does not work.
If it is only the "mkespfsimage" tools that is not compiling, maybe it is your Cygwin plain x86 "cc" that is missing.
What does it says when your try to call "cc --help" directly in Cygwin shell ?
is heatshrink installed?
By bkrajendra
#3286 Dear friends problem is solved.!
as I mentioned, my problem was not with XTENSA_TOOLS_ROOT,
because i was able to compile all other apps to their binaries without any problem.
For this I was not using crosstool.NG earlier.
My problem was only with image webpages.espfs generation not working.
Now i followed step by step guide at https://github.com/esp8266/esp8266-wiki/wiki/Toolchain
And it worked. webpages.espfs is now generating.
But eshttpd make is still giving error. I dnt know why.
For time being I'm using windows Cygwin to compile binaries.
[EDIT]
webpages.espfs Image generation do work in Cygwin32/64 now
as mentioned by lethe martinayotte and CheapB gcc was not installed in my cygwin32
I'm doing eshttpd make in lubuntu with crosstool.NG and now error I get is:
Code: Select allesp8266@esp8266-VirtualBox:/opt/Espressif/esphttpd$ make
CC user/cgi.c
CC user/cgiwifi.c
CC user/espfs.c
CC user/heatshrink_decoder.c
CC user/httpd.c
CC user/httpdespfs.c
CC user/io.c
CC user/stdout.c
CC user/user_main.c
AR build/httpd_app.a
LD build/httpd.out
/opt/Espressif/ESP8266_SDK/lib/libmain.a(app_main.o): In function `read_macaddr_from_otp':
(.irom0.text+0x7c): undefined reference to `wDev_ProcessFiq'
(.irom0.text+0x84): undefined reference to `lmacInit'
(.irom0.text+0x88): undefined reference to `wDev_Initialize'
(.irom0.text+0x8c): undefined reference to `pp_attach'
(.irom0.text+0x98): undefined reference to `pm_attach'
(.irom0.text+0x9c): undefined reference to `wDevEnableRx'
(.irom0.text+0xe3): undefined reference to `lmacInit'
(.irom0.text+0xec): undefined reference to `wDev_Initialize'
(.irom0.text+0xf2): undefined reference to `pp_attach'
(.irom0.text+0x115): undefined reference to `pm_attach'
(.irom0.text+0x126): undefined reference to `wDevEnableRx'
/opt/Espressif/ESP8266_SDK/lib/libmain.a(user_interface.o): In function `os_printf':
(.irom0.text+0x58): undefined reference to `pm_is_open'
(.irom0.text+0x5c): undefined reference to `pm_is_waked'
(.irom0.text+0x60): undefined reference to `pm_post'
(.irom0.text+0x6d): undefined reference to `pm_is_open'
(.irom0.text+0x93): undefined reference to `pm_is_waked'
(.irom0.text+0xba): undefined reference to `pm_post'
(.irom0.text+0x13c): undefined reference to `pm_is_waked'
(.irom0.text+0x144): undefined reference to `pm_is_open'
(.irom0.text+0x1d8): undefined reference to `pm_post'
(.irom0.text+0x204): undefined reference to `ppRecycleRxPkt'
(.irom0.text+0x20d): undefined reference to `ppRecycleRxPkt'
/opt/Espressif/ESP8266_SDK/lib/libmain.a(user_interface.o): In function `system_upgrade_reboot':
(.irom0.text+0x390): undefined reference to `pm_rtc_clock_cali_proc'
(.irom0.text+0x394): undefined reference to `pm_set_sleep_time'
/opt/Espressif/ESP8266_SDK/lib/libmain.a(user_interface.o): In function `system_deep_sleep':
(.irom0.text+0x4aa): undefined reference to `pm_rtc_clock_cali_proc'
(.irom0.text+0x4b2): undefined reference to `pm_set_sleep_time'
/opt/Espressif/ESP8266_SDK/lib/libmain.a(user_interface.o): In function `system_print_meminfo':
(.irom0.text+0x6ad): undefined reference to `pm_rtc_clock_cali_proc'
/opt/Espressif/ESP8266_SDK/lib/libmain.a(user_interface.o): In function `wifi_softap_set_config':
(.irom0.text+0x14f0): undefined reference to `pm_set_sleep_type_from_upper'
(.irom0.text+0x1501): undefined reference to `pm_set_sleep_type_from_upper'
/opt/Espressif/ESP8266_SDK/lib/libphy.a(phy_chip_v6.o): In function `chip_v6_rxmax_ext':
(.irom0.text+0x2424): undefined reference to `uart_tx_flush'
(.irom0.text+0x242d): undefined reference to `uart_tx_flush'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o):(.irom0.text+0x10): undefined reference to `ppTxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o):(.irom0.text+0xea): undefined reference to `ppTxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o):(.irom0.text+0x330): undefined reference to `ic_bss_info_update'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o):(.irom0.text+0x334): undefined reference to `ppRegisterTxCallback'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o):(.irom0.text+0x363): undefined reference to `ic_bss_info_update'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o):(.irom0.text+0x37a): undefined reference to `ppRegisterTxCallback'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o): In function `hostap_handle_timer':
(.irom0.text+0x509): undefined reference to `ppRecycleRxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_hostap.o): In function `hostap_input':
(.irom0.text+0xd3b): undefined reference to `ppTxPkt'
(.irom0.text+0xd70): undefined reference to `ic_set_vif'
(.irom0.text+0xdd3): undefined reference to `ic_set_vif'
(.irom0.text+0xe68): undefined reference to `esf_buf_recycle'
(.irom0.text+0xf00): undefined reference to `ic_bss_info_update'
(.irom0.text+0xf10): undefined reference to `ic_set_vif'
(.irom0.text+0xf23): undefined reference to `esf_buf_recycle'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_ht.o): In function `ieee80211_add_htinfo_vendor':
(.irom0.text+0x90c): undefined reference to `rc_get_trc_by_index'
(.irom0.text+0xa4e): undefined reference to `rc_get_trc_by_index'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_input.o): In function `ieee80211_deliver_data':
(.irom0.text+0x56): undefined reference to `ppRecycleRxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o):(.irom0.text+0x8): undefined reference to `esf_buf_alloc'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o): In function `ieee80211_output_pbuf':
(.irom0.text+0x92): undefined reference to `esf_buf_alloc'
(.irom0.text+0xce): undefined reference to `esf_buf_recycle'
(.irom0.text+0x1a1): undefined reference to `rc_get_trc_by_index'
(.irom0.text+0x255): undefined reference to `ppTxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o): In function `ieee80211_mgmt_output':
(.irom0.text+0x495): undefined reference to `ppTxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o): In function `ieee80211_send_nulldata':
(.irom0.text+0x5cf): undefined reference to `rc_get_trc_by_index'
(.irom0.text+0x5de): undefined reference to `ppTxPkt'
(.irom0.text+0x72b): undefined reference to `esf_buf_recycle'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o): In function `ieee80211_send_probereq':
(.irom0.text+0xb7f): undefined reference to `ppTxPkt'
(.irom0.text+0xb92): undefined reference to `rc_get_trc_by_index'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o): In function `ieee80211_getcapinfo':
(.irom0.text+0xcb4): undefined reference to `esf_buf_recycle'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o): In function `ieee80211_send_mgmt':
(.irom0.text+0xe65): undefined reference to `rc_get_trc_by_index'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_output.o): In function `ieee80211_alloc_proberesp':
(.irom0.text+0x1499): undefined reference to `rc_get_trc_by_index'
(.irom0.text+0x14a9): undefined reference to `ppTxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_power.o): In function `ieee80211_pwrsave':
(.irom0.text+0x90): undefined reference to `esf_buf_recycle'
(.irom0.text+0xfa): undefined reference to `ppTxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_proto.o): In function `ieee80211_proto_attach':
(.irom0.text+0x1e): undefined reference to `ppRegisterTxCallback'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_scan.o): In function `ieee80211_scan_attach':
(.irom0.text+0x90): undefined reference to `pm_scan_lock'
(.irom0.text+0xb9): undefined reference to `pm_is_open'
(.irom0.text+0xc2): undefined reference to `pm_is_waked'
(.irom0.text+0xcc): undefined reference to `pm_post'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_scan.o): In function `scan_start':
(.irom0.text+0x100): undefined reference to `pm_scan_lock'
(.irom0.text+0x2cb): undefined reference to `ppTxPkt'
(.irom0.text+0x36c): undefined reference to `wDev_SetRxPolicy'
(.irom0.text+0x370): undefined reference to `pm_force_scan_unlock'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_scan.o): In function `scan_cancel':
(.irom0.text+0x3e7): undefined reference to `wDev_SetRxPolicy'
(.irom0.text+0x3f9): undefined reference to `wDev_SetRxPolicy'
(.irom0.text+0x430): undefined reference to `pm_is_open'
(.irom0.text+0x438): undefined reference to `pm_force_scan_unlock'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_scan.o): In function `scan_remove_probe_ssid':
(.irom0.text+0x69c): undefined reference to `ppCheckTxIdle'
(.irom0.text+0x6ab): undefined reference to `ppCheckTxIdle'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_sta.o): In function `ieee80211_sta_new_state':
(.irom0.text+0x2a8): undefined reference to `ppRecycleRxPkt'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_sta.o): In function `ieee80211_parse_wmeparams':
(.irom0.text+0x8fc): undefined reference to `ic_bss_info_update'
(.irom0.text+0xb0f): undefined reference to `ic_set_vif'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_attach':
(.irom0.text+0x3e): undefined reference to `ppRegisterTxCallback'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_sta_connect_cmd':
(.irom0.text+0x125): undefined reference to `wDev_SetRxPolicy'
(.irom0.text+0x136): undefined reference to `wDev_SetRxPolicy'
(.irom0.text+0x1c5): undefined reference to `wDev_SetRxPolicy'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_start_handoff_cb':
(.irom0.text+0x5b0): undefined reference to `wDev_remove_KeyEntry'
(.irom0.text+0x5dc): undefined reference to `wDev_remove_KeyEntry'
(.irom0.text+0x5e4): undefined reference to `wDev_remove_KeyEntry'
(.irom0.text+0x5ec): undefined reference to `wDev_remove_KeyEntry'
(.irom0.text+0x5f4): undefined reference to `wDev_remove_KeyEntry'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_rc_update_rssi':
(.irom0.text+0xdc4): undefined reference to `ic_set_sta'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_rc_update_state_metric':
(.irom0.text+0xdf2): undefined reference to `ic_set_sta'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_update_bss':
(.irom0.text+0xeb3): undefined reference to `ic_set_sta'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_sta_leave':
(.irom0.text+0x1097): undefined reference to `ic_set_sta'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(wl_cnx.o): In function `cnx_sta_associated':
(.irom0.text+0x1186): undefined reference to `ic_set_sta'
/opt/Espressif/ESP8266_SDK/lib/libnet80211.a(ieee80211_ets.o): In function `ieee80211_getmgtframe':
(.irom0.text+0x31): undefined reference to `esf_buf_alloc'
/opt/Espressif/ESP8266_SDK/lib/libwpa.a(wpa_auth.o):(.irom0.text+0xc): undefined reference to `ic_remove_key'
/opt/Espressif/ESP8266_SDK/lib/libwpa.a(wpa_auth.o):(.irom0.text+0x10): undefined reference to `ic_set_key'
/opt/Espressif/ESP8266_SDK/lib/libwpa.a(wpa_auth.o):(.irom0.text+0x74): undefined reference to `ic_remove_key'
/opt/Espressif/ESP8266_SDK/lib/libwpa.a(wpa_auth.o):(.irom0.text+0xd6): undefined reference to `ic_set_key'
/opt/Espressif/ESP8266_SDK/lib/libwpa.a(wpa_main.o):(.irom0.text+0x1f): undefined reference to `ic_set_key'
/opt/Espressif/ESP8266_SDK/lib/libwpa.a(wpa_main.o): In function `eagle_auth_done':
(.irom0.text+0x2ae): undefined reference to `ppRegisterTxCallback'
make: *** [build/httpd.out] Error 1
Please see if you can have a look!
By martinayotte
#3290 As I mentionned in the other thread :
@bkrajendra, did you try to compile with sdk_v0.9.2 or sdk_v0.9.3 ?
Because it seems that many of the undefined mentioned are located in libphy.a in 0.9.2 are now moved in libpp.a in 0.9.3.
In this case, you only need to add "pp" to LIBS of the esphttpd Makefile.
